Question about Zanussi 18 in. DA4342 Free-standing Dishwasher
No water getting to washer
I have zanussi d s 17 i am getting water up to washer but not inside,could it be a faulty valve.
Hope you can help Thanks
    Novelist:
  • 161 Answers
Yes, but I would check to make sure power is getting to the valve before replacing. Usually if you hear a buzzing, then power is going to the valve. The best way is with a meter on A/C setting then put it on OHM setting to check the solenoids on the valve. I would buy a meter at an appliance parts store so they can show you how to use it. It's not that difficult and everyone should have one.
Posted on Nov 30, 2008
Fabric conditioner dispenser does not empty
Hello Patrick Compton,
Start on PAGE 17 of your REGULAR MAINTENANCE...
in your owners manual... You are most probably looking at a MINOR MAINTENANCE ISSUE... in your dispenser drawer...!!
Else...
You are going to be looking for the valve... for your conditioner/softner dispenser...
CHECK out owners manual (below)
Look up you ORIGINAL parts number and get three estimates!!
Good luck
Hope this helps.
Zanussi ZWF12070 S1 User Manual
Zanussi ZWF12070W1 Washing Machine Spares
Zanussi ZWF12070W1 Washing Machine in White
May 22, 2016 | Zanussi ZWF12070 Front Load Washer
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
Front load washer will not rinse with cold water. cold water is on no kinks in hose ,no sediment in filter. clothes come out hot .doug
THIS IS MORE THAN LIKELY CAUSED BY A FAULTY WATER VALVE AND IN ORDER TO PERMANENTLY FIX THE PROBLEM IT WILL HAVE TO BE REPLACED. EVEN SMALL PARTICLES OF SAND OR SEDIMENT GETTING IN WILL JAM THE SOLENOIDS INSIDE THE VALVE. THERE IS HOWEVER A QUICK FIX YOU CAN PERFORM, YOU CAN SIMPLY SWITCH OVER THE COLD LINE TO THE HOT LINE AND THIS SHOULD TEMPORARILY FIX THIS PROBLEM PART NUMBER FOR THE INLET VALVE IS 8181694.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am constantly getting a E10 error on my Zanussi w1042w. what could be causing this?
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 14, 2009 | Washing Machines
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Mar 02, 2008 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Water in drum
It sounds like you have a faulty fill valve that is leaking by. The valve has an electric solenoid but also has a small diaphragm that needs to seat properly to keep the water supply from coming in. If the diaphragm is not seating correctly for whatever reason, water pressure alone can keep water filling into the wash tub. Even the smallest amount, over time can cause problems. One way to test the theory is to shut off the water supply before you go to bed. If the tub is still empty in the morning, more than likely you have a bad fill valve. Let me know if this helps.
Jul 09, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Jetsystem not working
It sound like an clogged inlet water line issue. Check for clean filters and inleat water valve.
Jun 29, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi 18 in. DA4342 Free-standing Dishwasher Logo
196 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
