Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
How do i install software ??
Okay so this is my first Mac and I am totally lost. I have downloaded software for my course on it but when I click on the exe file all I get is a load of jibberrish in the text edit thingy. I need help asap my assignments due in next week!!
  • dbeckles Nov 29, 2008
    Ahh...right okay. I'll have to check that I have possibly downloaded pc software. Adobe cs3 and office 07. I will have a look and see if I can find the right one.
  • 586 Answers
    For your convenience and time saving,I would suggest you to please visit the below link awhere you will find your required softwares and instruction also.And if don't have thing how to handle then you can get hepl online or by telephonic at the site.the link is as follows:
1-      http://support.apple.com/downloads/
2-      http://manuals.info.apple.com/en_US/MacBook_Pro_15inch_Late2008.pdf
Thanks for using fixya.
Posted on Nov 29, 2008
  • 10,515 Answers
Resolution Before Installing Read "Before You Install" information Read the "Before You Install" or "Read Me" type document if one is available for the software you are installing. This may list the system requirements and any known issues. The Knowledge Base contains many documents about software updates. Try searching on the name of your software update while using the Knowledge Base keyword "kbdload".
Have the administrator username and password available You must have an administrator username and password to install software updates.
Enough disk space Make sure you have enough disk space. Even small application or system updates may require a few hundred megabytes of space to complete the optimization phase of the installation. Mac OS X itself may require 3.0 GB of free space, or more, depending on the version and installation options you select.
Use Disk Utility if installing to resolve an issue Use Disk Utility to check the Mac OS X volume before installing, if you are installing or reinstalling to correct an issue. Tip: Mac OS X 10.3 and 10.4 and later check the target disk automatically during installation.
Do not use the computer while installing an update Though not required for most updates, you may want to avoid using the computer while installing updates. You may even want to restart the computer immediately before installing an update. Shut down the Classic environment to maximize the amount of memory available for the installation.
Choosing disk format (full installation / erase installation only) Mac OS X can be installed on volumes of different formats. These disk formats have different features and characteristics. If you also plan to use Mac OS 9 or don't have a preference, you should choose Mac OS Extended (HFS Plus) format instead of UNIX File System (UFS). Journaling is usually also desirable. More information is available in "Mac OS X: Choosing UFS or Mac OS Extended (HFS Plus) Formatting".
Is it an installation issue or a startup issue? Some installations restart the computer automatically, which you may not notice if you start an installation and then leave your computer. If you do not see the installer on your screen when you return, and the computer does not start up successfully, treat this as a startup issue. See "Mac OS X: Troubleshooting a Startup Issue".
Portable computers: Set Energy Saver preference Optimize Energy Saver Settings to Highest Performance. If you are installing on a portable computer, make sure that the computer is connected to the AC power while you are downloading and installing the update. During the update process, do not put your computer to sleep, and do not let it go to sleep.
Mac OS X 10.4 Tip: If installing Mac OS X 10.4 while started from your Install disc, you'll be alerted if AC power is not connected to your portable Mac.
Verifying the installation Check the build number If you are unsure that the installation was completed, check the software build number. If the build number of Mac OS X or other software has changed to reflect the new update, then all of the software has been installed.
Check logs (advanced technique) If an alert box appears with a message that says: "There was an error while installing," check the logs for the specific issue.
  • Installer log. When started up from an installation CD-ROM disc or installing a package file from a disk image, choose Show Log from the File menu (or Window menu with Mac OS X 10.4). If the information in the log window is not helpful, select the Show More Detail option. If you are going to call Apple, save the log file or write down the last few lines.
    These are the locations and names of the log files:
    • Mac OS X 10.2.8 or earlier: "Mac OS X Update" or "Mac OS X Log" in /Library/Receipts/ folder
    • Mac OS X 10.3 or later: "install.log" in /var/log folder
  • Software Update log. This log is available from the Software Update pane of System Preferences. This log just lists which update had an issue. It does not give you detailed information about the issue.
  • Console log. Use the Console utility to check the logs used by Mac OS X, which are "console.log" and "system.log". Look for messages containing the word "Install" or messages that appeared during the time of the installation.
Troubleshooting an unsuccessful installation If installing from CD-ROM If you have trouble using an installation CD-ROM, first see "Troubleshooting Mac OS X installation from CD or DVD".
Restart the computer and try again Restart the computer and try installing the update again. Some installation issues are not reproducible, you may succeed the second time.
Use Disk Utility Start up from the Mac OS X Install CD. Use the Disk Utility application to verify the disk with Repair Disk (not permissions) of the volume you are trying to install onto. After verification or any necessary repair, try the installation again.
Disconnect devices not used during installation and remove non-Apple RAM If the issue persists, disconnect any other drives you may have connected to your computer and retry your installation. Other devices could potentially affect your installation. Disconnect or remove anything that did not come with your computer. If removing all non-Apple memory would leave you with insufficient memory to install Mac OS X, then remove everything but the memory. If your issue persists, you may have an issue with your non-Apple memory.
Try a different software update source or CD if possible Software Updates for Mac OS X and Apple applications for Mac OS X are often available three different ways:
  • Software Update preferences.
  • Your iDisk (if you use .Mac)
  • Standalone installer from Apple Downloads.
Try getting the software from a different source, or download it again.
Try a new administrator account Creating a new administrator account and using it to install the update may lead to success. If you don't know how to do this, see the "If the issue occurs in Mac OS X or in various applications" section of this document: Mac OS X: How to troubleshoot a software issue.
If this works, log out and back in as your normal user. You may delete the new administrator user, if desired.
Installation fails during "optimization" If the installation fails during "optimization," all of the software was installed. There is no risk of an "incomplete installation." The optimization phase of an installation only affects performance and not stability or features. You may force optimization to be repeated by reinstalling the software. If you were using the Software Update pane of System Preferences on the first attempt, you will need to download the standalone installer of the same software from Apple Downloads in order to reinstall the software.
Consider the RAM For installations from a disc, marginal-quality memory can contribute to installation issues; issues that may not otherwise be apparent in day-to-day computer tasks. Remove some of the RAM from your computer, but not so much that you are below the minimum required to install the software).
Erase install Erase installs often succeed where installations without erasing fail. You should make sure you have a working backup of your important data before erasing the volume. Due to the extreme nature of this solution, you may wish to try all other steps first.
Warning: This procedure deletes all data on the targeted volume. Back up any data you wish to keep before performing this step.
About "Downgrade" installations You should not reinstall an earlier version of the same software over a later version. These "downgrade" installs may seem to work, but Apple does not test nor recommend downgrade installations in most cases. Some installers prevent downgrade installations. If you need to reinstall an earlier version of Mac OS X, erase your disk first or choose the erase option in the Mac OS X Installer. Be sure to reinstall any software updates after reinstalling the operating system
  • Apple Master
  • 13,433 Answers
Exe files are for windows computers, dmg setup files are for map, make sure you download the mac version of the program, which program are you trying to install?
LOST MY CD PRINTER DRIVER (HP DESKJET D1663
Hi even you lost the printer drivers cd ,still you can install the drivers from the below link
http://tinyurl.com/4th4a4x
Feb 25, 2011 | Computers & Internet
I have lost my cd install for my printer. how do i fix it?
CLICK HERE to download the driver.
  1. It will ask you select the operating system, then click on next.
  2. Next step, it will ask you to select what to download
  3. Click on the driver link, then look for the HP deskjet full feature software and driver.
  4. Download the driver by clicking on the download link.
  5. Another window will pop up once you click on the download the link. (Its up to you if you want to run it or save it, but I highly suggest to save it so you don't need to download the software over and over again.)
  6. Run the driver.
  7. Install the software.
It should be okay by then.
Good Luck :)
Feb 08, 2011 | HP DeskJet F4280 All In One Printer InkJet
I have missplaced/lost the software CD somewhere while shifting house for my Lexmark-X5150 printer and now I want to download into my new laptop.Please suggest how and from which site I can download the...
I suggest not to plug the printer to your computer yet. Download and install the software first. For the software, click on this link to the Lexmark website. http://bit.ly/curEed. Click on the Microsoft, Macintosh, or Linux/Unix dropdown to choose the version of the operating system of your computer. No drivers for latest Mac OS. If you're using Windows 7, you can use the Vista drivers. Download and install the software. Follow the instructions on the software. Hope this helps.
Jun 13, 2010 | Lexmark X5150 All-In-One InkJet Printer
Need software for the scanner
Canon have all their drivers available on their website. However, if he installed the printer driver then I would expect that he also installed the scanner driver (on every Canon Multi I have installed they are both done together automatically by the installer software.
To find out if the driver is there, open your applications folder and look for 'Image Capture'.
Open it and see if identifies your scanner (make sure it's switched on of course). See if you can scan from there.
Post back and let us know.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I lost my lexmark 2500 cd software. whare can I download a new
Hi Alex,
You can go to:
Lexmark X2500 Downloads
There is a Mac tab and Microsoft tab. Click the one that you have. The different drivers are listed for each operating system.
If you need more help, just Comment back.
Thanks for using Fixya.
Nov 22, 2009 | Lexmark All-in-One Printer with PictBridge
Msi motherboards
Off course you cant, but your processor model, make and whether x64 or x86. Mac computers are suppossed to be totally diferent beacause the communication language(internal) is different from DOS based softwares that microdoft uses. You need an Apple PC to run mac OS....sodeep
Mar 22, 2009 | Intel Computers & Internet
Lost software cd
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:PIXMA MX700 office all in one inkjet printer
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file, double click on the file , then if you getintroubles,followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:someprinterdoesnot work on Vista, if you do not find any driverdownloadfor Vistaonyour model page, that means your model is not Vistacompatible.
Oct 27, 2008 | Canon MX700 Office All-In-One InkJet...
Cannon pixma mp150 instalation disc not registaring on my pc
Download software from this link : MP150
Select Mac OS X or Mac OS depending on your Mac OS version.
Reinstall the software from download.
Oct 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Download lexmark x2350 software
Hi kisha.
Lexmark X2350 drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
32 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
