Question about Hitachi C43-F500 43" Rear Projection Television
I have problem on my hitachi prjection television
Green color dominate the rest to color on my Hitachi projection television
mode C43fd 2000
    Problem Solver:
  • 6 Answers
My father in law had a similar problem it was the bulb to the projector caused the colors to seperate out... like $1500 to replace so he upgraded to a new TV
Posted on Apr 25, 2009
Colors are way off. Too much orange, colors eratic.
You need a convergence kit. Search Goo*le and tvrepairkits.com will have a kit make for your specific tv.
Replace with the kit and your colors will be better than ever!
Thank you!
Jun 14, 2011 | Hitachi 57F510 57" Rear Projection...
I have hitachi prjection hdtv, kinda old recently the color green stands out way too much.. pretty much all you see is green
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Hitachi 51F59 51" HDTV Projection...
My hitachi prjection tv does not come on. It flashes the temp and lamp lights and then shuts down. Is my lamp burned out?
Chances are real good the lamp is bad. Open the lamp door, remove the lamp and see if it is shattered or scorched on the inside. If so, replacing the lamp will fix it. Only replace it with a genuine Hitachi part. The part number should be on the lamp cage.
Good luck,
Skyassoc
Dec 14, 2010 | Hitachi 46F500 46" Rear Projection...
What causing the dominate red screen to display on my Hitachi Rear Projection, MDL 60v500a.
If it's red everywhere, even the white areas, the first thing to check would be the color wheel. It's probably not turning and the red section is the part presently in the projector beam. The color wheel is a disk with red, green and blue sectors. Failure modes include bad bearings in the wheel or its motor, a break in the drive mechanism (belt? I haven't seen the inside of this model), motor burnout or motor drive electronics.
Unplug the set, remove the back and find the color wheel. Try turning it gently by hand to see if it is binding. Plug the set in, turn it on and watch the wheel to see if it spins. Caution: unless you are familiar with electronics work, avoid contact with any part of the inside of the set, especially around the lamp, while it is powered. You could get burned by hot components around the lamp or electrically shocked. At this point, all you are doing is observing.
Oct 22, 2010 | Hitachi 60V500 60" Rear Projection...
Hitachi 51s700 noise and color problem
bad connection . check for bad solder inside
Sep 11, 2009 | Hitachi 51S700 51" Rear Projection...
The picture comes in good except that the colors red,pink and blue has become real dominant I tried to adjust the color but those 3 colors reall show through
Hitachi was know for their problems with picture tub sets. Every time is was the main the board was bad that was control green gun.
Aug 12, 2009 | Hitachi Televison & Video
No green
green crt weak? poss demod circuit prob.
Dec 10, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi C43-F500 43" Rear Projection Television Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
