I have a tecra S1 toshiba laptop, when i ON the laptop, the power LED goes ON, the harddisk seems to be operating, but there is not any video on the screen, could it be the mother board?
    Scholar:
  • 69 Answers
In order to resolve the issue follow the steps below:
1. Turn off the laptop
2.Remove the battery
3.Remove the power adapter
4.Press and hold the power button on laptop for 1 minute in order to remove static charge.
5.Relese the power button after 1 minute and reinsert the battery and power adapter.
6.Turn the laptop on.
This should solve your problem. If the issue persists follow the steps below:
Turn off the laptop
1. Remove the Hard disk
2. Remove the memory RAM.
3.Wait for 2-3 minutes
4.Reinsert the hard disk and RAM.
5.Turn the laptop ON.
This shpuld resolve the issue. Is the issue persists than it is a clearly indication of mother board malfunction and even could be with display.
Thank you.
Posted on Nov 29, 2008
My Toshiba Tecra S1 Laptop has lines up and
hello,
the flex of your is either getting weak or it has shifted from its original location.. the flex is what connects the screen to the panel of the laptop and when it has a problem you experience lines on your screen..
what you should do is to open up your laptop and try to set the flex to its normal position and see if it stops the lines on your scree, if it doesn't then you have to change the flex
if you cant open your laptop,get someone with experience to help you
goodluckk
Feb 18, 2010 | Toshiba Tecra S1 Laptop Notebook
Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
Jan 29, 2010 | Toshiba Tecra S1 Laptop Notebook
VGA problem
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 24, 2009 | Toshiba Tecra S1 Notebook
I have a problem on my Toshiba Tecra S1 Laptop, Suddenly it stopes working, The main problem is the power indicator front lamp showed the electricity is plugging and the machine also turned on while their...
check your inveter in screen or vga cable maybe los only,.. if the power indicator is working and if you turn on the uit is working but no desplay.. check first the inverter.. if the inverter not problem it means need to open you pc and check the board...
if this underwarranty bring to warranty..
Jun 05, 2009 | Toshiba Tecra S1 Notebook
Cant install windows XP on my Toshiba Tecra S1 laptop.
Where did you get your disk from? It sounds like you may have a bad install disk?
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
How to get driver vga
Here is the link to the driver
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
seach for your driver these, all you need is the laptop model to find it..
or
www.drivermagician.com thiss will detect and install the drivers for you.
Jul 23, 2008 | Toshiba Tecra S1 Notebook
Toshiba tecra 9000 wont start
Blue screens are generally operating system failure. You will need to reinstall your XP home. Format the drive NTFS, instead of FAT32. If you have any problems during or after the reload, then the hard drive is the failure and will need replaced.
Jul 01, 2008 | Toshiba Tecra S1 Notebook
Video Drivers
Goto the following link and search as permodel.
Try this:
Thanks
Iqbal
Mar 23, 2008 | Toshiba Tecra S1 Notebook
Computers & Internet Logo
79 people viewed this question
Alun Cox
David Payne
David Payne
