My computer does not recharge any more... i think the problem is to do with something inside the charging port...
    Scholar:
  • 160 Answers
You may have a bad battery or a bad charging unit. if the pc still works when plugged into the charger, it's probably a bad battery.
Posted on Nov 29, 2008
I purchased the 7 Port Hub. You advise that using the hub for recharging a phone is not advisable. The package included a second cable that enabled the hub to be powered from a USB port of my computer. My...
Usually the directions tell you to do something a certain way, because it might (repeat might) cause damage if not done the way they direct. Occasionally there are other reasons, such as it might cause slow charging. In addition, I have found there are different cables that look alike, yet one is for data and one is for charging. My advice is: if you want to charge your phone, get a charging cable, and plug it into an adapter made for your phone. If you are using your phone with your computer, then get a data cable and use a USB port on your computer.
Dec 01, 2017 | Computers & Internet
2001 Ford Focus recharge ac?
You charge it at the smaller of the two AC lines from the compressor using a pressure gage, when the low side pressure is at 28-32 PSI the system is charged, I think you are overcharging the system which loads up the engine and causes it to slow down. CHECK THE LOW SIDE PRESSURE!
Aug 24, 2017 | 2001 Ford Focus
Is it possible to charge my olympus fe-46 from my computer?
In a convoluted way. The FE-46 uses standard AA batteries. You may use either disposable alkaline or lithium batteries, or rechargeables. If you use rechargeables then you must charge them outside the camera. There are chargers that run from a computer USB port, and there are even AA batteries that plug into a USB port. However, you canNOT charge the batteries by connecting your camera to your computer.
Jul 29, 2011 | Olympus FE-46 Digital Camera
I have a kodak 530 camera. can I charge my battery on my laptop? I have lost the plug for the wall.
That depends on the camera. Kodak has at least three different cameras with a 530 in the model number.
The C530 uses rechargeable or disposable batteries. If you want to charge rechargeable batteries, you will have to use a separate charger, the camera does not charge them.
The M530 will charge via a computer's USB port. However, be aware not all computer USB ports put out enough current to charge batteries.
The V530 requires the power adapter or an external dock to charge the battery.
From your description I think you mean the M530 but I can't be sure. If you still have problems, please feel free to ask, specifying the exact model number.
Apr 24, 2011 | Cameras
1998 GMC Sierra Pickup Air Condition will not hold Freon Charge. Noticed Seal missing on valve core...how to replace Or could it be something else . Thanks
This is possible as the cap with an o-ring inside is considered the primary seal and not neccessarily the schrader valve on these service ports. I think alot of problems in this area could be avoided by the use of these caps but for some reason they are not that important to many as they are seemingly always gone,off,missing or not re-installed after services.However,I would not assume this is the only leak therfore system inspection and leak checking is definatley in order. A flouro-dye oil charge that detects leaks quite well under black light and electronic "sniffing" may be a corrective measure at this point and finally once the systems charge is recovered,insure the system will hold full vacuum(near 30 in depending on altitude) for a indefinate amount of time before recharging system to level.
Aug 14, 2009 | 1998 GMC Sierra
My walkman mp3 player wont turn on!! how do i get it to turn on? it hasn't gotten wet or anything and i cat think of any reason why it shouldnt be working
When you plug it into the USB port of your computer does it do anything? If it doesn't then your player is likely dead. If it does do something then it likely just needs a full recharge.
Jul 26, 2009 | Sony Network Walkman NW-E005 MP3 Player
Battery or the camera cradel
Parts or a new cradle are hard to find. I don't think Fuji makes them any more, although, depending on where you live, that country's distribution source may still have stock. What we sell our customers is a small charger which recharges the battery outside of the camera. They are about $10 US and plug into the USB port on any computer.
May 25, 2009 | Fuji FinePix Z3 Digital Camera
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
How to recharge mastero fron computer useing ubs port
You can try charging the unit with the supplied uSb cable but the output on the USB is so low that it might only partially charge the battery or it will take eons to charge
Feb 11, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
