Question about Navman Tracker 5100X GPS Receiver
Backlight on NAVMAN 5100 does not work
Good daylight contrast, no backlight for night time use I have the exact same issue
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Lets try the basic:
  • press the power button briefly, display controls would be shown;
  • press arrow right to brighten;
  • press arrow down to select contrast;
  • press arrow right to increase contrast;
  • press ENT to accept and save settings.
Should this not work, then the unit has a hardware fault, specifically the back light bulbs themselves or the electronic circuitry supplying their power and controlling their brightness level.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    President:
  • 1,952 Answers
Interface with a compass and configurable data display
  • 53 Answers
Hello..click the link below n checkout page no 10 and 38 to fix your problem
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
  • 10,515 Answers
Reset the gps reciever.........
Thnx.
    Scholar:
  • 174 Answers
Try to do a reset.
Can not get the back light to light system is working but backlight is not
use a torch to see settings on the screen. if backlight setting is at max. turn off to reset to low then set high. backlight is first to go if battery is getting low.
Jun 12, 2011 | Navman TRACKER 5505 GPS Receiver
305 edge screen is hard to read
There is a contrast parameter in the "Parameters" -> System -> Display
You can increase it. Otherwise you may use backlight by short press on start button. duration of backlight also tuned on the same menu.
Jan 21, 2011 | Garmin Edge 305 GPS Receiver
Time is ahead buy one hour and how u adjust clock
go into the options for the unit. there should be an option for time setting. you may be running into daylight savings time issues so if there is a check mark in automatically set for daylight savings time unmark it.
Jan 24, 2010 | Navman S30 Car GPS Receiver
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Display can hardly be seen even with backlight set to max and colour on sunlight
I have the same problem. The backlight in mine has blown. Its a small fluro type globe I we cant buy one anywhere......Any ideas other than nav,an ?
Jul 16, 2009 | Navman Tracker 5600 GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Backlight not working on my Navman Pin 570
On the main menu (Start-- Win Logo) go to settings. Then go to system at the bottom of the screen. Tap on Power. At the very bottom of the screen in small print go to "Adjust Backlight settings to conserve power". Click on "backlight" in blue print.
Apr 16, 2009 | Navman PiN 570 GPS Receiver
Myguide satnav 4200 - Night profile stays on all the time
I don't know how to fix it but i now a way of getting it back to it's original settings like formatting a computer so only do it if completely necessary. Insert the maps backup cd with your unit attatched to the computer by usb. An option of reinstalling original software will appear, click on this after 10 mins it should be back to how you first got it
Mar 28, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
Screen is not working
check the backlight power saving settings
Jul 24, 2008 | Navman PiN 570 GPS Receiver
Incorrect time
go to - preferences / Localize / Time / Time Zone and make sure you have the correct time zone selected.
Also check your daylight savings settings.
Mar 22, 2008 | Navman F20 GPS Receiver
Navman Tracker 5100X GPS Receiver Logo
83 people viewed this question
Top Navman GPS Experts
Iron
Iron
Are you a Navman GPS Expert? Answer questions, earn points and help others
