how to install linux on compaq presario cq40-144tu
Comments:
Nov 29, 2008
- Thanks skone,
Let me tell u the exact problem is that this notebook is only comaptible with windows vista and when u insert the (RedHat)linux AS v4 disc it ask for the drivers, i have come to know that if we change the SATA option to disable in BIOS then we can install the OS as required, but the problem is that this option is not available in BIOS, EVEN WE DOWNGRADED THE BIOS TO F v4.
Now i think u can analyse the situation.
-   i want use os linux(ubuntu) but its hard for me to find driver.. where can i find the driver and what the website to get it? -   azuan_CHAOS
Mar 03, 2009
-   Hello Sir, I have a compaq pressario CQ40 laptop with pre installed windows vista. Now I need to make it a dual boot machine by installing linux (preferably FC8 or FC10) in it along with vista. However, I am finding it impossible to install linux in it. Kindly help me out with it. In case I need to install certain drivers before installing linux, then kindly let me know what are the required drivers and also where to get them.
hrm... i'll just assume that this is the first time you've attempted anything with linux? There are vairous Linux distributions, with the Ubuntu flavour seeming to be the best one for the windows to linux switcher (IMO). I would try a live Ubuntu disc first to make sure it's what you're after, which can be downloaded here http://releases.ubuntu.com/intrepid/ubuntu-8.10-desktop-i386.iso
or if you're ready to dive straight in, here is the full version that you burn to a cd and then install http://www.ubuntu.com/getubuntu/download
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do...
(More)
My pro multi panel does not work in fs2004. Its lights up but none of the buttons or dials do anything either on the panel or in fs2004.
I disconnected the LCD projector from my ASUS UL30A. The screen remained black even after I used...
(More)
I disconnected the LCD projector from my ASUS UL30A. The screen remained black even after I used Control F8 that I had used with the projector. I had to reboot. The touchpad worked as I clicked on the Windows icon. Then the touchpad would not respond- the pointer will not move.
Loaded program and after it loaded plugged printer in and ''Found New Hardware'' window came up but...
(More)
Loaded program and after it loaded plugged printer in and ''Found New Hardware'' window came up but said it cannot find the hardware. The camera works on the printer but my computer cannot find the printer
I bought an akai XR 20 Beat Production Center and a midi cable to connect it to my mac, and it won't...
(More)
I bought an akai XR 20 Beat Production Center and a midi cable to connect it to my mac, and it won't work. any suggestions?? thank you!
