Question about Kenmore Elite 45986 Front Load Washer
Washer Drain Backup
I just found out that the drain line from my clothes washer to the main line is blocked with rocks. This is only a 3yr old house and I've had a plumber out to first attempt to snake the line and then did the scoping camerea. With the camera it was clear as day that I had small rocks blocking the line (2" line). They look like the same rocks that are put down for the bedding of a driveway. I have no idea how they got there but obviously it was some mistake during builing. Now I'm facing the decision of ripping up my basement and removing the blockage. I plan to move in a year and would rather not go through that expense and trouble. I can do a wash because the water does seep through the rocks but on high loads backs up into the wash room. Does anyone have idea on what I can do to control the flow of water out of the washer into the drain. I'd even consider buying a new washing that has that feature. Or replacing the existing washer drain pipe with something that had a flow control. Any ideas?
Where is your washer located? If it is located in an outer area (Garage, outdoor porch) you can probably get away with just draining the water into your yard. Its not the most legal or pretty way of dealing with it, but that's my suggestions. I've actually had a plumber make this same suggestion to me when I was having problems with blocked drain pipes at my house.
Posted on Feb 08, 2007
SOURCE:
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
My machine is going through a wash cycle and has stopped with a "drainage blocked" light
Look for a kinked drain hose. Make sure drain hose is not plugged. Remove drain hose from washer and inspect drain outlet on washer is not plugged. Stick your finger inside and feel for any clothing fabric ect blocking drain line. The washer may have a built-in screen that is plugged. You may need to remove the back cover of the washer and inspect drain hoses for any kinks or blockages.
Sep 26, 2009 | Bosch WFMC 3200 Front Load Washer
Water won't drain during spin cycle
fill the washer with watertake your drain hose and get it lower then the washer see if water comes out freely if so your problem sounds like the drain pump, pending on the year of washer i have found small clothing items in the drain hose and pump not a common problem but has happened
Aug 23, 2009 | Maytag Washing Machines
Machine will not spin water out of cloths.
A tranny or clutch problem is typically associated with a complaint of "the washer will not spin"
If you're complaint is now "washer will not drain" (you can see water at bottom of tub at end of cycle); I would check and test the water pump and ensure your drain-line is clear (machine & house-line). Note: You can double-check by having your washer drain into a bucket or something (outside).
You may have a defective pump / pump impeller which will not give the amount of pressure needed to drain completely (broken blade or something).
What was your original problem? Who advised it was the tranny/clutch? Does your washer have a belt?
Jan 27, 2009 | GE WBSR3140DW Top Load Washer
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore elite he 3 front load washer
Have you checked the drain pump reservoir? This is a common point where debris collects and causes slow drain and no drain issues with this washer. The following link provides guidance on how to check:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you have checked the drain pump, have you checked ALL the drain lines? The drain line that leads from the bottom of the wash tub to the inlet side of the wash pump is another common area where items get stuck. Its also an area that most consumers forget to check. I have found small articles of clothing such as wash cloths, underwear and socks, stuck in this hose causing slow drain problems. NOTE: It is recommended that you use garment bags for small items).
If you verify everything and still have the "F02" Long Drain error, it is recommended by the manufacturer that you replace the drain pump. If anything has been in the drain pump for any length of time, it could potentially damage the pump impeller and/or motor. The pump may be running, but it may not be pumping.
I hope you find this information helpful. Let me know if I can assist you further.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine with "nd" code
Check the drain hose. If it's not kinked or blocked then it could be the drain pump. I just pulled out two rocks from my drain pump. I found step-by-step instructions with pictures here:
http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
Mar 03, 2008 | Maytag MAH2400A Front Load Washer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
60 people viewed this question
Sal De
fordexpert
yobo007
yobo007
