Question about D-Link DIR-625 (790069292637) Wireless Router
When my computer is connected directly to the modem, i am able to obtain internet. However if plug the enthernet cable from my computer into a Dlink DIR615 router in the hope of creating a wireless network, the Dlink wireless router says there is no internet connection. Whats wrong!!
  • Chrisd115 Dec 17, 2008
    I have the same router and it does the same thing the Ethernet wire is connected in the right port but wen i plug it in the router only 3 lights come on instead of the 5 dat turn on and it says i have no internet connection nd i tried doing wat it sed to turn everything off but it still doesnt work
  • 345 Answers
Make sure your modem is plugged into your WAN port on your router and your computer is plugged into your LAN port on the router, then turn everything off (unplug what doesn't have a switch) then turn the modem on first and let all the lights come on on the modem, then turn the router on and let all the lights come on on it then turn the computer on. Don't turn the next item on until the previous item has all the lights on that are going to come on.
Good Luck
Posted on Nov 30, 2008
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    Globe symbol won't turn green.
    I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
    This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
    1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
    2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
    3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
    4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
    5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
    Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
    After firmware upgrade can't get router to connect to internet
    Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password. Unplug your router and your cable or DSL modem. Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports. Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer. Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties. Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically. Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
    Apr 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    I hooked up my DLink VWR and cannot get internet connectivity
    If you connect the computer directly to the modem, does it work?
    If that works then the modem is working.
    Now connect the computer to the router and the modem to the router.
    You will need to open the set up page of the router to check the settings of the router.
    You can set up the router without the CD also.
    It is very easy.
    Click Here for step by step instructions about how to set up the router
    Dec 28, 2009 | D-Link Vonage-enabled Wireless Router...
    I don't know how to hook up the dlink to the computer. Does it plug into the modem or directly into the computer?? I on my own...my son hooked it up before so I'm not sure how to do it. Can anyone guide...
    There's a cable that comes from the modem that plugs into the WAN port on the dlink router. Then you connect one of the other ports(1,2,3, or 4) into the network card on your computer. The connection and network cable look like a phone cord/connection just bigger.
    Sep 24, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
    Linskys wireless-g broadband router not connecting to network
    first thing, we need to know what this d-link is... Is this a modem? or another router? Can you check its model #, perhaps at the back? How many ports does it have? To verify your internet connection, try connecting your computer to the dlink and check its IP address (Go to Start> Run> type "cmd". On the black window, type "ipconfig"). Do you have internet connection when your pc is straight to the dlink?
    I'm thinking that dlink is conflicting with the linksys settings. If it is, we need to change the IP address of the linksys router. Post back what you find out.
    Jun 07, 2009 | Linksys Wireless-G Broadband Router
    Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
    On which port of the D-link router did you plug the WRT160N router?
    Do this setup.
    Disconnect the WRT160N from D-link.
    Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
    Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
    You should be able to access the internet.
    Oct 08, 2008 | Computers & Internet
    Internet problem connection.....
    your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
    Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
    D-Link DIR-625 (790069292637) Wireless Router Logo
    135 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
