Question about Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card
No signal on monitor when card is seated
My PC wont show any display when this card is installed, I have 400w power supply.
using SATA hdd , core 2 quad 2 gb ram
when i install this card, monitor wont give any signal, just orange light on power button, ( it turns green when display is showing up ) and when i remove the card, it works fine with integrated video card.
It worked fine for about 1.5 week , then yesterday morning, it stopped working when i turned my pc on.
  • bilalghouri Nov 29, 2008
    already tried everything, as i said, card was working fine a week ago !
  • 31 Answers
The problem occured probably because of a power shortage of motherboard battery malfunction, if your motherboard has an integrated graphics card you then need to enter setup and disable it or choose which graphis card your pc has to use but you have to do this while connected to the on-board vga slot as the other one won't be working, you will problably find the choice under the
'integrated periferals" menu in the setup menu, and to access it you have to press the "DEL" button when your pc starts-F10 in some devices-
Posted on Nov 29, 2008
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
Power light goes on and fan is on but the monitor says no signal. all connections have been checked and system rebooted, still says no signal. It also has a graphics card that recomends 400w power supply...
That's most likely your issue you definately don't want to run a recommended 400W on 250 you might get away with 300-400, but I doubt 250 is giving the card enough power to run and give you display. You, could unplug your Hdd, cd/dvd drive basically everything except motherboard,powersupply, ram, cpu, and video card to see if that lowers the power load enough to get an image, which would then mean its definately the lack of power and you need a new power supply.
May 12, 2011 | Computers & Internet
When I power on my pc the power on indicator goes on but the display on the monitor shows no signal. what could be the problem?
Hi and welcome kweya_ellam !
Verify the connections and the power supply of your monitor ( on/of ) .
Otherwise your HDD or worse , your motherboard are dead .
Most of the time , you can retreive your data from a damaged HDD :
Extract the drive out of your pc . Place it in an external usb box and connect it to a healthy computer or connect it as secundary right inside the computer to the motherboard with the correct interface ( IDE or Sata ) .
Best regards ,
Fanaudi .
Feb 20, 2011 | Mercury P4VM800M7 Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Jan 27, 2011 | ASUS K8V-MX Motherboard
Problemas con el video
I also need Your OS.
Before
making yourself nuts, test the monitor on another PC or laptop. If you use a laptop to test the monitor and it doesn't automatically detect an external monitor when booting, use the "F" function keys along the top of the keyboard to tell the laptop to shift to the external display. Remember that we are testing just to see if the monitor is live, it doesn't matter if the screen settings are wrong and the display looks funny. If it doesn't work on a known good computer, the problem is with the monitor, not your PC. If a faint image is detectable on an LCD screen, the problem is with the backlight or the inverter that powers the backlight. A loud buzz coming from an LCD monitor is most likely the inverter circuit failing, though it can go on getting louder for years before it pops.
Assuming the system power comes up, does the monitor power come on? Monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can also hear older monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't always have a simple power cord, either. Some LCD monitors are powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating, though you can also check for live output with a DC voltmeter. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seat it all the way.
If you see a message on the screen that includes "power" in it, like: "attach graphics card power", "no power to video adapter", etc, it means that you have a PCI Express or older AGP video card that requires more power than the motherboard can supply through the bus. This means you need to run a power cable directly from the power supply to the video adapter, inside the PC. If it's a new build, you may have forgotten or not seated the connector firmly. If it was a working PC, either the power supply lead has failed, the power supply itself has problems, the cable worked loose, or some hardware on the video card has failed.
Earlier video cards that required additional power from the power supply usually took a Molex connector, the same 4 pin connector used to power non-SATA drives. Newer power supplies include one or two six pin PCI Express supplementary connectors designed for power hungry graphics cards. Some PCI Express cards, in the absence of a six pin supplementary lead, will accept two 4 pin Molex leads.
Dec 23, 2010 | ASUS P5RD1-VM Motherboard
Hello Guys, i my monitor will not display anything even if the system unit is running? and processor is abnormally heating, i just bought a new vga card and it started this, i have intel core 2 duo @...
hurm,try change the processor fan.. or your monitor did not support the vga card.... monitor have the resolution.. or you can change the power supply to 500w..
Oct 08, 2010 | CTX S762A 17" LCD Monitor
There is no display in the monitor when power is on. how to repam
1. Check with the Power supply:
2. Check with the Hard Disk:
Most probably, your hard disk doesn't work. First check the IDE or SATA cable connecting your motherboard and the HDD. Detach first cable wires and then reconnect it. Try to put it on. IF still it doesn't try to replace a cable (IDE or SATA). If it still don't work with that. Have another computer and slave the HDD from the PC not displayed and check disk by running a DOS Command prompt by typing "cmd" then type "chkdsk" to see if the HDD works.
3. If the hard disk is ok, try to use another computer replace it with the Power Supply from the computer that doesn't display. When it is connected, switch on press "del" or "F1" or "F2" to log to CMOS. Try to look for "Health PC" section and try to see if the battery is ok. One way to determine the power is ok is looking at power input to 12 v to 12.6v. If it's lower than 12v your power supply must be replaced.
Try one of these steps.
Jun 20, 2009 | Dell Inspiron 530 Desktop Computer
Recently built a PC Power is On with No Display
Well depending on your bios version, it could be an array of things.
First try removing the video card and re-seating it.
Then re-seat the RAM.
If the problem persists re-seat the CPU.
Let us know the exact model of your motherboard so we can better troubleshoot your problem.
When you turn on your computer the system does a POST (Power On Self Test). If the POST sees an eror it will tell the BIOS (Basic Input Output System) and the BIOS will beep a code or display a code that indicated the problem.
Different motherboards contain different BIOS versions. BIOSes use different beep codes for problems depending on the manufacturer.
Mar 24, 2009 | Abit IN9 32X-MAX Motherboard
Building a new PC, cannot get LCD to work
try with other ram if everything fails then motherboard is the culprit
Dec 23, 2008 | E-Machines eMachines T3830 PC Desktop
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card Logo
147 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
