Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Display doesn't light up
I'm having problem with my display on my printer. It doesn't light up to see any menu options. Has anyone had this problem or know what I need to do to fix it?
  • 114 Answers
Probably the back lights are off, probably u will need to send it (to a dealer) to get replaced.
Posted on Jan 19, 2007
I'm getting the message FAIL:head VLTG turn off printer error 6134 this is on a Brother GT-541 direct to garment printer. Can you tell me what I have to do to fix this issue? Thanks!
http://www.brother-usa.com/ModelDocuments/Consumer/Basic%20Instruction%20Manual/BIM_GT_541_EN_2767.PDF
  • Find the "Ink" key on your Brother printer. This key also may be labeled "Ink/Reports," "Ink Management/Reports" or "Ink Management." Press the key to bring up the menu on the LCD display.
  • Step 2Select the "Cleaning" option by using the up and down navigation key. Press "Menu/Set."
  • Find the color on the displayed list that's not printing on your Brother printer by using the navigation key. If more than one color isn't printing, select the "All" option. Press "Menu/Set."
    Step 4Wait for the printer to complete the cleaning cycle, which involves cleaning the print head nozzle. During this time, the LCD will display the words "Cleaning" and "Please Wait." The date and time will return to the LCD display when the printer is done cleaning.
  • Sep 01, 2016 | Brother Office Equipment & Supplies
    Problem has a red light and it says paper out but it has paper in the button.
    From memory I think there is an option to calibrate the Paper Out Sensor, in the Tech Access Menu,
    Press the LINE FEED and ENTER buttons for five seconds until the printer flashes up TECH ACCESS on
    Then access the menus as described below.
    1. Press the MENU button
    2. Press the DOWN ARROW button until the display reads TEST MENU
    3. Press the DOWN ARROW button until the display reads DIAG
    4. Press ENTER
    5. Press the DOWN ARROW until the display reads CAL-PAPER
    6. Press ENTER
    7. Press the DOWN ARROW until the display reads CALL PAPER PAPER OUT
    8. Press the ENTER button
    9. Follow the Onscreen Instructions
    If the above is not in your printer menu look for a PAPER OUT THRESHOLD option (PAPTHR)? Increase this value.
    The TECH ACCESS menu should have a METER function which will show voltage change readings for the PAPER OUT Sensor, enter the Meter Mode and select the PAPER OUT option and insert and remove paper to ensure there is at least a 3 volt voltage swing from paper in to paper out.
    If you get voltage swing but not 3 Volt adjust the paper out sensor position to see if you can improve this reading.
    If there is no voltage swing its likely the paper sensor is faulty.
    May 06, 2015 | TallyGenicom 6312 Matrix Printer
    No data to macbook screen
    For computers with Mac OS X 10.8 or later, if you have trouble getting your display to work with the computer, access the System Preferences menu and selection the Displays option. Then, press and hold the Option key. In the bottom right corner of the Displays window, you should see a Detect Displays button. Click that button to force the Mac OS to show all the displays, including the macbook's own display.
    Otherwise, try resetting the PRAM:
    by holding down the Command+Option+P+R keys on your keybord when you turn it on untill you hear the startup chime.
    Happy New Year!
    Kerry
    May 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
    Lg tv cf20s12e
    CHECK TV OSD(ON SCREEN DISPLAY ) SETTING
    Jul 19, 2013 | Televison & Video
    Tally 2250
    Measure with a ruler the size of the form in inches that you are going to use .
    Calculate the number of lines you have by relating it to the Line Density using the formula
    Form Length = Form Size * Line Density
    For example for 11 inch paper at 6 lpi = 11 * 6 = 66 Lines
    You must disable the Printers Menu Lock before you can change any settings - (power on holding down SETUP)
    Press SET UP button on the Control Panel.
    Select the MENU Option on the Control Panel Display.
    Select the NEXT Option on the Control Panel Display until PAPER is displayed.
    Select the PAPER Option on the Control Panel Display by pressing the button directly beneath it.
    Select the Desired Paper Path for the Form Length change - The different Paper Paths can be stepped through by using the NEXT Option on the Control Panel Display.
    Select Paper Path by pressing the button directly beneath it.
    Select FORMLEN by pressing the button directly beneath it.
    Select LINES and then increase or decrease the value on the Control
    Panel Display by using the two arrow buttons until the desired length in lines has been achieved.
    Select the SET Option on the Control Panel Display by pressing the button directly beneath it.
    Set the Printer back ON-LINE by pressing the ON-LINE button.
    This will set the form length on the printer, see the support section of www.dascom.co.uk for more info
    Sep 18, 2008 | Tally T2250 Matrix Printer
    Tally T8106
    To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
    • Power the printer on while holding down MENU/ENTER key
    • Release the key when the display shows "Utility Menu Clear FC. Roll"
    • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
    • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
    • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
    • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
    Jan 28, 2008 | Tally T8106 Laser Printer
    Error Message ('replace belt CG')
    1. Power the printer on while holding down MENU/ENTER key
    2. Release the key when the display shows "Utility Menu Clear FC Roll"
    3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
    4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
    5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
    6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
    Jul 12, 2007 | Tally T8006 Laser Printer
    Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
