Question about Sony Walkman NWZ-B105F MP3 Player
My sony Mp3 is not working
I have a sony walkman Mp3 player-NWD-B105F, when i switch it on the the icons are displayed, then if i press the play/pause button it automatically says power off and restarts again..
  • 7 more comments
  • ash_rough Dec 03, 2008
    My mp3 is having a problem. When I turn on my mp3 and press the play button, it turns off and turns again.
    I've tried everything including update the firmware, format, and reset my mp3, but it still not works. my mp3 having a problem to play the songs. when i press the play button, it will turns off and restarts again...
  • georz Dec 04, 2008
    no lo identifica el computador
  • Anonymous Dec 14, 2008
    My sony walkman wont play songs regardless the ability to turn it on.
  • uk_kuri84 Feb 09, 2009
    yeah i have the same problem, it switched off because i left it on all night, but when i want to charge it it doesnt seem to charge and i reseted it but it doesnt seem to work!!!
  • dannit Feb 10, 2009
    When I turn it off it says "power off.. then turns off the screen, but after some seconds it says "power off".. and then again.. and again. If I turn it on, any option I select goes to "power off". When I fully recharge it this doesn't happen, but when I turn it off, it keeps on the "power off" cycle, discharging the battery.
  • birdie30467 Feb 14, 2009
    The problem started suddenly all of a sudden. The player goes into a sequence of events: power off -> restarting and displaying icons and when I click to choose the music library, it turns off. Can this be solved if I reformat? If so, how do I do that? I even tried to reset using apin at the back side reset hole. Still it does not do anything. Is there any virus that sneeked into this player via my PC and if so, can I replace the AuoRun and associated files? Please help to fix this problem. Thanks.
    Birdie
  • crua Feb 17, 2009
    Mine started the same thing yesterday. Have tried reset, flashed the new firmware version, reformatted, and it is still doing the same thing. The on off button doesn't work and when you hit the play button it shuts off then restarts.
  • karthik77 Mar 22, 2009
    When I click on the play/pause button the player switches off and restarts again. The power button is also not working.. :(
    Problem Solver:
How to get C:\Windows\System32\DriverStore\FileRepository that you call STMP?because i try to search there is nothing names folder driverstore. pls help me and ASAP pls.
Posted on Oct 20, 2011
  • 3 Answers
I tried something and it seemed to work ( though how long it will lst I don't know ).
1. Let the battery go dead
2. Put the player in the USB port
3. Update with latest Flash Driver ( check the format option )
4. When finished, remove from the USB port WITHOUT disabling the port through Windows ( just pull it out )
5. Hold down the play button and keep it held down.
6. Navigate to Settings.
7. Go to Restart option and click ok. You have to be quick here since you have to release the Play button. Once you get to the next level , keep the play button pressed or else it will shut off
8. Once it says restart is complete, press power button to shut it off.
9. If you have enough power, give it a try otherwise plug it back in USB port for about 5 to 10 min to get a charge.
10. Remove from USB port the same way as before.
Posted on Feb 19, 2009
  • crua Feb 19, 2009
    Well, the solution I tried worked for about 2 hours. Now it is back to doing it again. ARGHHH !!!!! If you try the solution I posted, remembe to back up your songs beforehand because they will be erased
  • crua Feb 27, 2009
    From crua:
    FIXED IT !!!!!!!!!!!!!!!!!!!!!!!! FIXED IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Did this 3 days ago and it is still working, so I think it is fixed. This is what I did. It seems the chip that Sony uses is a Sigmetel 3600. You have to download a driver for it. This is where I got it :
    http://support.packardbell.com/global/it...
    Now run that program. Next, follow these steps. I don't know if the first 2 steps are needed , but I did it anyway. Plug your mp3 in USB slot.
    1. Run the Sony firmware update - get that from Sony site.
    2. Under Windows , format the drive to FAT, not FAT 32
    Now comes the tricky part. ( The following is for Vista, Xp should work same way )
    3. Remove your mp3 from USB port. It should still be doing what it was doing.
    4. Hold down the play button and CONTINUE to hold it down as you insert it in USB port. Keep holding it until you hear the computer beep that it acknowledges it ( if doesn't after 30 sec, probably has - just didn't beep ). Release the button.
    5. Go into Device Manager. You will see a folder for Player Recovery Device or STMP3600 ( or something similar ). Open that folder and right click on the file in that folder ( probably called same thing ). Choose Update Driver.
    6. Choose Browse My computer for Driver software .
    7. Click browse button and go to the following folder:
    8. Find the folder that starts with STMP.. Highlight it and click next. There may be more than one folder with that name, choose the one with the latest date.
    9. You may get a windows error saying it is a dig signed. Accept it anyway.
    10. Once updated, remove your mp3.
    11. If it doesn't work, run the Sony firmmware update again ( this time with the format box checked ). If it still doesn't work, try steps 4- 10 again.
Dear sir, when i turn on my nwd b105f walkman, it is swhowing that' boot error, shutting down'. it was functioning smoothly before and i tried to delete the songs and formatted. this error happened after...
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue:
NOTE: If the message you receive is Format OK? , select Cancel .
1. Connect the player to the computer.
2. Click Start and then click My Computer .
NOTE: If the Portable Device box appears, click Cancel .
3. In the My Computer window, under Other , double click the icon for your portable player.
4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu.
5. In the Format box, click OK .
6. In the Format Complete box, click OK .
7. Close the My Computer windows.
8. Disconnect the portable player from the computer.
9. If it is not on, press the power button to turn it on.
10. Press the selector button repeatedly until Settings is highlighted.
11. Press the Play / Pause button.
12. Press the selector button repeatedly until Format is highlighted.
13. Press the Play / Pause button.
14. Press the selector button one time to highlight OK .
15. Press the Play / Pause button.
16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player.
17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Thanks for using FixYa.
Mar 10, 2011 | Sony Walkman NWZ-B105F MP3 Player
My sony NWD B105 mp3 player Has frozen mid song. None of the buttons or functions work so I can't even turn it off and on again.what can I do?
there is a rest button at the backside of the walkman.put a needel there and press it...your walkman will be turned off.now on it again it will start working as it was before
Dec 07, 2010 | Sony Walkman NWZ-B105F MP3 Player
BOOT ERROR
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 25, 2009 | Sony NWZ-B103FBLK MP3 Player
Sony music player NWD-103F
will son u need 2 fix it lol like **** man that realy sux my mp3 isnt working 2 ...and thats realy making me feel like ****
Jun 20, 2009 | Sony Walkman NWZ-B105F MP3 Player
I will lose all dirver of my walkman
i want some softwares or dirvers of the model number NWZ-B105F SERIAL NO.2153301
Apr 16, 2009 | Sony Walkman NWZ-B105F MP3 Player
Sony Walkman - Digital Music Player NWD-B105F
I had the exact same problem with my girlfriends sony nwd-b105 mp3 player. I fixed it by downloading the firmware version 1.2, which can be found here at the sony support link below.
http://support.sony-europe.com/dna/wm/nwf/nwf.aspx?site=&m=NWD-B105&site=odw_en_GB&odw_model=NWD-B105
- Backup your mp3 files
- Make sure your mp3 device is NOT plugged in
- Run the firmware executable
- When it asks for it plug in the mp3 device
- Check option: format data area
- Press Start
- When finished, take the mp3 device out and press the power button
- If everything went well it is creating a database again and will function correctly as usual
- Copy your mp3 files back to the mp3 device
- Enjoy your music again!
Apr 28, 2008 | Sony NWZ-B103FBLK MP3 Player
Sony Walkman NWZ-B105F MP3 Player Logo
1,389 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
