Question about Sony NW-A1000 MP3 Player
Error Code 82040100
When I try to import files and synchronise the device, I receive the Error Code 82040100. Even after several attempts at re-starting my PC and closing and re-opening Connect, and also re-setting the walkman, I still receive the same message. Strange because I have been able to import files before. Has anyone else had this problem?
  • Anonymous Mar 28, 2014
    I have a file i just purchased from smash up the Studio. I have the file in the same file where I keep all my midi files from Smash up the Studio. it is this new file I can't open. computer tells me operation failed because of bad format. I use Reason record software. i have no problem opening the other midi files only this new file
ERROR CODE 82040100 SOLUTION: here's what I did to solve this problem: -update walkman's firmware to latest version (3.0) -control panel > system > hardware > device manager uninstall the driver for the walkman (remove device) -now connect player can initialize the player again, but I installed Sonicstage CP 4 which is much better anyway.
Posted on Mar 04, 2007
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
HP scanjet 8279 displays an error 05 and won't clear. I can't turn the machine off either. I have to manually disconnect the machine from power source to try to reboot it. It turns back on then after a few...
Error code 5 denotes a device failed and requires an arbitrator/administrator. If an installed device requests a resource type and detects that there is no arbitrator, computer users will receive this error code. The arbitrator/administrator redirects the system in a chosen field. It cannot happen if the computer has a firewall or has user restrictions. The administrator does this for security purposes. The system denies admission to other users to protect information and important data.
A user is denied access to some files or program. As a result, the user will not be able to obtain information from certain files nor actions like delete, restore, or edit can be executed.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
Update the driver of the files. Use the click start control panel administrive tools Device Manager scroll to ports(Com<p)+to expand you should see a communication port& Ecp printer port you might see a yellow question mark? right click to uninstall and reinstall the appropriate device. Run wizard in the Add New Hardware in Control Panel
hope this helps
Feb 10, 2011 | HP ScanJet 8270 Flatbed Scanner
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Ntldr cd boot fault
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Mar 31, 2010 | Computers & Internet
Windows BSOD on all restarts, even in Safe Mode and even if I start with video in VGA mode. Stop code is 0x0000007E plus four more codes in parentheses. During Safe Mode restart the last file to appear on...
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware incompatibility with Windows XP because all the installed drivers are Windows XP drivers:
  • You receive the STOP 0x7E error when you first start the computer.
  • You receive the STOP 0x7E error after you run the Setup program.
  • You did not install any third-party drivers during the installation of Windows.
However, if you receive the STOP 0x7E error after you upgrade from Windows 2000 Professional, or if you recently added a new hardware device, this issue might be an incompatible driver or an incompatible hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Oct 26, 2009 | Dell Inspiron 700M Notebook
Receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
Jun 23, 2009 | Veo Advanced Connect Webcam
Problems connecting
It think its something to do with the DRM on your PC download this OMG Status file to check to see if all is working OK. It will tell you if the SDK is working
DRM OMG Status Check v1.0
It will also tell you the error code for example error 80040154 means that the application software is not loaded.
LOL
Jun 02, 2009 | Sony NW-A1000 MP3 Player
I have loaded Garmin Trip & Waypoint Manager plus downloaded the latest ver of Garmin Mapsource for vista. I am attempting to unlock OZtopo & contours maps Ver 2 onto a PC running Windows Vista home...
Open C:\garmin directory then right click on the .exe file "Unlock wizard". Open this file as administrator and behoild it works. Even though you may already have full administrative rights as I did.
Jun 29, 2008 | Garmin GPS
Philips HDD 1620 will not let me view pictures
Open the mp3 player on your computer and make another folder next to it and put the folder containing your picture in that new folder.
Jun 04, 2006 | Philips HDD1630 MP3 Player
Sony NW-A1000 MP3 Player Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
