Question about Sharp VT-G21 21 in. TV/VCR Combo
Picture brarred, focus responding but cant improve picture quality
I have a problem with my tv, audio is perfect,but picture can be seen but focus too poor, hardly can ready menu disply or channel numbers. focus is reponding but cant improve picture or graphics clarity. i thought it was processor i.c TB1226DN,but after changing problem still persit, i will be greatiful for your solution
  • keith royes May 12, 2008
    i try change the fly back and its the same
CHANGE CRT SOCKET
Posted on Jan 14, 2008
    Scholar:
  • 168 Answers
Did u try adjusting the focus knob in the flyback transformer? this device is connected to the anode of the picture tube which produces the high voltage so be very careful of adjusting it. dont touch the wire linking to the tube. thats approximately more than 21,ooo volts dc! good luck!
Posted on Jan 19, 2007
Poor focus on a 0.3 megapixel camera supplied with the machine (built in webcam) I have tried to adjust the focus, but these controls are shaded out in the supplied software.
You cant do anything to improve the quality as its the hardware. you cant change the quality of hardware by using any software. You can download other photo editing tools to alter images but the supplied software is the best.
Jan 02, 2011 | Toshiba Computers & Internet
JVC 32" CRT TV BLURRED PICTURE POOR TEXT QUALITY POOR IMAGE DEFINITION CANNOT IMPROVE USING NORMAL COMMANDS
Seems to me you should have to contact a technician to adjust manually the circuit side of it. Usually the screen and focus control knob on the flyback to adjust the settings.
Sep 23, 2009 | JVC AV-32D305 32" TV
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Grainy Sky+ Tv picture
Can't say it's a fix but when you press the tv button to make the picture better, cover the end of the remote and press sky so the tv and box don't pick it up.
It's more of a work around than a fix!
Mar 30, 2009 | Panasonic TH-42PHD8UK 42 in. Plasma...
New Samsung LN40A550 LCD TV: picture is not crisp.
If you play with blu-Ray with HDMI, you will see the amazing picture quality.
I guaranty.
Jan 27, 2009 | Samsung LN40A550 LCD TV
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
The picture via my Onkyo-sr674 has degraded
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Jul 10, 2017 | Onkyo TX-SR674 Receiver
Samsung projection tv HCN4226W. Blue does not focus when using perfect focus. The picture improves if the tv is on for a long time, but the center does not focus properly.
This is a good indication that there are poor solder connections at the convergence ICs. If you can solder, you can fix this yourself. The convergence ICs are large black ICs attached to a heat sink and will be marked STKxxx. Resolder the pins for these and the problem should be resolved.
Dan
Jul 10, 2008 | Televison & Video
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Not clear picture
If this is an HD set and you are using a SD signal I have seen many disappointed people because the upgrade that takes place in the digital video circuit is far from perfect. It will not look like it did at the store without HD!
Apr 21, 2007 | Samsung TXN2798HF 27" TV
Open Questions:
Sharp VT-G21 21 in. TV/VCR Combo Logo
99 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
