Question about Acer TravelMate 2700 Notebook
Laptop won't charge while it is turned on
Laptop won;t charge while it is turned on, but when it is shut down it will begin charging again. when the laptop is opened and the power button is pushed, the light that shows it is charging is turned off and it is left on battery power alone.
  • 93 Answers
If the laptop is working FINE when you plug AC only or battery only, you better using AC only when you at home.
If you really need carry out the laptop, you better:
Keep full charge when the laptop in shutdown condition/ you are not using the laptop.and then you can use it until the battery need full charge again in another shutdown condition.
Unless you can find the solution from Acer web with some kind upgrade software or BIOS, because it sounds like power design problem....
Posted on Dec 01, 2008
Have a look under your control panel for power options.
I'm using Vista but should basically be the same. Click on "Change when CPU sleeps"
Go into advanced power settings.Will prob give you option with your power plan. Mine
on high performance but you can change the others if you want.. Look under battery options
and see if you maybe have you battery option maybe turned off?? I've got a Acer Aspire 4920G
so it should be around the same operation. Let me know what come of it.
Posted on Nov 30, 2008
Hi, I have a 1.5kva cyberpower inverter installed but it doesn't charge the batteries even after displaying the input voltage on screen. It will just drain the batteries and then shut down the output.
Unless a battery is completely drained, over time it begins charging less and less. If your laptop seems to run for less and less time each time you unplug it from the wall, you probably need to reset it. This is a simple process.
Disable all power-saving and automatic shutdown programs or routines on your computer. If your laptop power plan dims the screen or goes into sleep mode after a few minutes of idle time, disable that. Unplug the laptop's AC adapter cord. Drain the laptop battery. You can just use the laptop until it shuts itself off, or you can wander away and come back when it's gone dark. Make sure that you do not turn it off or allow itself to shut down to conserve power; you want it to run out of power entirely. If you happen to be in a hurry, feel free to exhaust the computer more quickly by playing a 3D graphics-intensive computer game or watching a bit of online video content. Plug the AC adapter back in and wait for the charging indicator light for your laptop to come back on. Once you see that the laptop has begun charging again you are free to do whatever you like, so long as you do not turn the computer off until the battery is fully charged.
Feb 27, 2013 | Computers & Internet
Laptop won't charge?
battery is dead. change the battery.
Aug 12, 2012 | Computers & Internet
Laptop shuts down when using battery
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 31, 2012 | Compaq Presario Notebook
My Advent laptop keeps shutting down whenever i remove the charger any suggestions ?
Aug 18, 2011 | Computers & Internet
VISTA PC DOES NOT STAT laptop vista battery went down to 10% Vista was shut down and was connected to power supply try several times to start the pc but it just does not start if pc is shut does the...
The battery continues to charge if the computer is off. The computer probably won't turn on because the battery is so low. It might not be charging because the power cord might not be plugged into a wall plug that is on. The plug might be on a switch. Find a plug that you know for sure that is on then plug it in there and try again.
Jul 29, 2011 | Computers & Internet
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Hello, I have a Dell Inspiron 1501. It has shut down on me in the middle of my session and now will not come back on. I plugged in the adapter for it to charge a few mins then the charging light shows but...
Don't think as a battery error, if you can use without the battery ,pls check with ac adapter without battery.because there may be a short circuit with charging unit or power side, you have to test before blow up the unit. if blow up chip or mos fet, it will be hard to repair.
May 05, 2017 | Dell InspironTM 1501 Notebook
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
Acer TravelMate 2700 Notebook Logo
248 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
