Marisolis, I believe these molding are 2 sided taped on, patients, heat gun on low, firm thin plastic spatula,adhesive remover are required. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Remove Car Truck Door Molding
The Best Way to Remove Body Side Molding Adhesive eHow
Car Debadging Tutorial GMC Denali Truck debagding
SOURCE: How to remove the front door driver side pannel / molding?
Hi Leon, I have a E34 1995 5 series and had to take door cards off. They're predominantly held on by plastic button clips around the edge/circumference of the door card HOWEVER there is a couple of screws hidden, 1 is behind the chrome door pull/lever a little round plastic cover hides it the other is behind the top of door handle maybe on yours behind door mirror electric adjuster button. one scew is philips the other Torx when pulling the card off the clips try a large flat/wide implement to prise it away as you may breaks some of the clips (£2/3 eBay) One more thing the door handle locates into a grip from behind you'll need a long screwdriver to push the tang up to release it. All the above should be well similar to your model. Oh! nearly forgot remember to unscrew/take off the door pin that goes up and down when locked/unlocked
Paul 'W'
Onyer~EDson(:0)~[><
SOURCE: Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
SOURCE: 93 exterior rear door handle replacement
You probably won't get it off from outside. The two bolts go from inside out I believe.
SOURCE: lower body side cladding or molding im trying to find the piece on the front passenger door
I am parting several 93-97 Intrepid, Intrepid Sport, and Intrepid ES....which part of the ground effects do you need, door part(which door) or the rocker panel part (front or rear, left or rght)....email me at [email protected]
SOURCE: How do i install body welt (molding around driver's side door)
if youre talking about the rubber that seals the door to the car when its closed, you just push that ****** on, and it slides neatly into place. its pretty straightforward. Sometimes it can be a pain to get to stay in place, but after a few days, it shoul conform to the plastic interior panels and stay in place.
is that what you were talking about?
