Question about Panasonic NV-GS35 Mini DV Digital Camcorder
No LCD Display when opened at 90 degree
LCD display is blank when opened at 90 degrees and shows horizontal grey lines. Thanks to provide a solution.
  • theWheelinOz Dec 20, 2008
    sounds like my problem - how do you actually remove the screen to change the ribbon? External screws seem not to offer access... thanks.
  • Rgprasad Jan 14, 2009
    Hi sir,
    when i am opening the LCD display is not comming coz LCD ribbon is broken that i can see so how to open LCD display kindly know me.
    Thanks & Regards.
    Prasad ghadi.
    Problem Solver:
  • 19 Answers
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Posted on Jan 17, 2007
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Change screen orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Dec 14, 2012 | Dell Computers & Internet
Screen does not display
I had the same problem. more than likely your connector cable between the camera and the display has become brittle over time and is beginning to break. as you open the screen the small wires inside the cable are separating. mine went from 30 deg view to 90 deg no display as yours is now, then 30 deg fuzzy display (cant make out the picture like a VHS when it needs heads cleaned) then the cable gave in and snapped. all the way through. Simply not a lasting camera. I got quotes and it was about $200 to fix. for that price these days u will pick up a better camera anyway. Good luck
Nov 19, 2008 | Panasonic NV-DS60 Mini DV Digital...
Desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
May 31, 2008 | Acer X193W LCD Monitor
Panasonic NV-GS35 Mini DV Digital Camcorder Logo
416 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
