Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
What would cause my craftsman lt 1000 to chew up ground drive belt?
    Brigadier General:
  • 6,468 Answers
A bad pulley - bent- binding bearing-loose belt guides
Posted on Jun 07, 2012
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
  • 246 Answers
SOURCE: i need a owners manuel for Craftsman LT 1000 Model# 917.272650
Hello bostont1228:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
SOURCE: craftsman LT 1000 deck belt diagram
my clutch belt will not stay on the pulleys Craftsman 42 in. LT 1000
Posted on Aug 20, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
SOURCE: how to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Posted on Apr 21, 2010
Testimonial: "this was a great help thanks a million"
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
How to install drive belt for craftsmen lt 1000
Remove deck belt from engine pulley, then remove the idler pulley for the drive belt, remove drive belt and reinstall.
Jul 11, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Could you provide me with a manual on Sears LT 1000 Riding Mower model # 917.271652?
Try online at "SearsParts" and type in your model number and you will see how to get the information you want. Be blessed.
Jun 19, 2013 | Garden
Craftsman lt 1000 no spark
remove the connector on the side of the engine that goes to the coil this will test the wiring side of the system is still no spark remove the upper engine cover and see if mice chewed the wires under there if still no problem found you have a bad coil
Jul 02, 2012 | Craftsman Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Could you send me a diagram how the drive belt goes around the pullys thanks its a craftsman lt 1000 not sure of the year model
Hi and welcome to FixYa, I am Kelly.
Here is the diagram:
http://www.brandywineits.com/graphics/LT1000/PulleyConfig.jpg
One of the major problems on the LT 1000 is that the belt gets installed wrong side out. Just make sure the V of the belt rests in all of the mandrel and drive pulleys correctly.
Thanks for choosing FixYa,
Kelly
May 04, 2011 | Garden
Craftsman LT 1000 deck belt diagram
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
125 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
