Question about Konica Minolta Magicolor 2450 Printer
Magiccolor 2450 factory reset password
Is there a way to completely reset to factory defaults?  Also what is the password to enter service mode to diagnose a problem.
  • smgbuddy Nov 29, 2008
    Thank you for the help.. And quick response.!!
    But the problem seems to be beyond connected with the system admin tool. I upgraded the firmware for mac 10.4 over a year ago and it started to act flakey ever since.. Dropping usb connections etc.
    It has not been used for awhile and I recently reconnected it since another printer failed. I got one print out and it seemed to freeze up several times when I was spooling the next. Now during boot it makes all the correct sounds but the LCD screen stays in "initializing" and the ready light never comes on. I still have access to the front panel menus and I can get to the service menu scree. it asks for a password, appears to be all digits. I tried "1234" but no go..
    I think I should be able to reset the defaults from there? also is there a way to flush out the updated firmware and go back to the original, which seemed to work fine.
Thanks great link.. But after digging around all night I did find this fix. This would allow me to just reload the entire firmware.
On a non-functional printer the firmware can not be rewritten or upgraded using the firmware update utility.
The controller firmware (in a XXXXXX.sys format) will have to be sent to the printer via the parallel port.
Connect the machine to the PC using an IEEE 1284 parallel cable. (The printer should be switched off.)
Copy the firmware data (XXXXXX.sys) to any directory on the PC.
Holding down the Menu Select key and arrow up key on the control panel at the same time, turn on the
printer’s power switch.
To select YES or NO for each of the items shown below, use the > or < key. Then press the Menu
Select key.
[UPDATE PRINTER]: YES
[REPLACE CODE]: YES
  [REPLACE ALL FONT]: NO
  [REPLACE SYS FONT]: NO
  [UPDATE NOW]: YES
Make sure that the message SEND DATA NOW appears on the control panel.
Start the Command Prompt on your PC and go to the directory in which the firmware data is stored.
Type copy /b XXXXXX.sys lpt1: and then press the Enter key (XXXXXX is the firmware data file name).
After the firmware update has completed, the printer will reboot.
Posted on Nov 29, 2008
    Sergeant:
    Champion:
  • 274 Answers
Here is a PDF copy of the Reference Guide, if you don't have it...
DOWNLOAD HERE (Left Click to read online, Right Click to save on PC)
Password on page 120
Factory Reset on page 133
  • Ricky Ostrom
    Ricky Ostrom Nov 29, 2008
    Password can be up to 16 characters, by default it is "off" on the printer panel.
    You might try this forum, these guys are great...
    FixYourOwnPrinter.com
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
To factory reset the SDR-B74301
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
CCTV Networking Technical Support
Sep 18, 2017 | Samsung Home Security
Resor factury shdls router ct524(hardwair)??????No reset button on the back of the modem!!!!!!!!!!!!
The factory reset is completed via the configuration page. Enter the IP address of the router in your browser and then login. For
example, if the IP address is 192.168.1.1, enter http:// 192.168.1.1 Look for Erase and Reboot and click to reset to factory defaults. Caution! If you reset your device to the factory default, any changes to
parameters will be lost and all parameters will revert to their default values.
Try root at the default username and password unless it was changed. (or root and 12345). I am not aware of a hardware factory reset i.e. pin hole.
Dec 17, 2014 | Computers & Internet
HOW DO I MASTER RESET MY SGH-A847 WITH THE HARD KEYS?
  1. While in standby mode, press the right soft key for Menu
  2. Select Settings
  3. Select Phone
  4. Select Reset Settings
  5. Enter the password, using the keypad
    • If no password has been created, enter 0000
  6. Press the left soft key for Confirm
  7. Enter the password again to confirm, using the keypad
  8. Press the left soft key for OK
  9. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Note: The device will power cycle to complete the restting. All device settings will be reset to factory settings.
Jul 18, 2014 | Samsung Good Condition Rugby Ii Sgh-a847...
How do i factory reset on my SGH-A847?
  2. Select Settings
  3. Select Phone
Jul 18, 2014 | Samsung SGH Cell Phones
Forgot password on the acer netbook with windows7
Have you forgot windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Jun 20, 2012 | Acer Tablets & eReaders
How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Oct 06, 2009 | Office Equipment & Supplies
Magicolor 2450 Service menu password
Are you familiar with the printer's PageScopeWeb Connection.
You can access it with your web browser and reset the printer from that page. Instructions for IE are on page 117. The password is SYSADMIN. The printer's ip address is 192.168.1.2 per the manual. unless you have it networked with a different IP.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2450/rg2450e.pdf
Hope this helps,
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2008 | Minolta magicolor 2400W Laser Printer
Kyocera Copier Password (KM-4050)
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
Nov 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Ricoh IS200e Web interface password
default login: scanner
default password: password
Jul 17, 2008 | Office Equipment & Supplies
Konica Minolta Magicolor 2450 Printer Logo
2,311 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
