Question about Intel D850MV Motherboard
Best cpu hi all, i want to get the most speed out of this mobo witch cpu is fastest here? TY
  • avi mistriel
    avi mistriel Jan 18, 2007
    so nothing faster will work?!
    no 3.0 for me?!
  • avi mistriel
    avi mistriel Jan 19, 2007
    ok gut it,thank you very .
    President:
  • 2,961 Answers
Click below for all suported processors, obviously higher ghz listed faster the processor. http://www.intel.com/design/motherbd/mv/mv_proc.htm
Posted on Jan 17, 2007
  • andrew pester
    andrew pester Jan 18, 2007
    You won't notice any speed difference between a 2.6ghz and a 3.2ghz anyway.
    If you want to speed up system more, fit the maximum amount of memory for your mobo.
R610 cpu compatibility
Hi Edward,
This depends on the specs of the other mobo. You cannot damage the mobo or CPU by plugging it in and switching on, so the easiest way to test this would be to place it in the other mobo and switch on. If you see a display on-screen it means the processor is compatible with the mobo.
Best wishes,
Graeme.
Jan 05, 2014 | Fujitsu Siemens Celsius R610 PC Desktop
I have an old IBM Netvista 6794 pc with its original IBM motherboard that it came with P4 pc with a 2.0ghz cpu. Now I want to change the processor. My question is can a 3.6ghz or 3.4ghz p4 intel cpu work...
Unlikely, I would think that the best processor you could use would be a 3.0Ghz or maybe a 3.06Ghz. If you look at the motherboard part number you will be able to find out from the manufacturers what the fastest CPU is. A lot depends on the FSB on the mobo and the Bios version. You need a "Socket 478" processor I think you will find that the processors you are looking at are "Socket 775" ( this is the fitting socket for the processor) .
Feb 11, 2012 | Intel Computers & Internet
Witch is the fastest processor that can by plug d in A OPEN MX3L Mather board
According to cpu-upgrade, it looks like the fastest processor you can get is an Intel Celeron 533MHz. You can pick them up here for $72
Jul 21, 2011 | AOpen MX3L (91.88110.251) Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
What is the fastest cpu supported by MSI RS480M2-IL Motherboard?
alright here is your answer from msi themselves. you can use any of the following cpu's on this list.
CPU'S
also here is the manual for your reference
Your motherboard is a socket 939
Manual
Mar 26, 2010 | MSI RS480M2-IL Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
Intel D850MV Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
