I hear clicking noise near the power supply.
SOURCE: I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
SOURCE: I have a Sony Bravia KDL-S40A12U have had 3
if you cant fix the problem and need to buy another tv, let me know if you have the stand the tv came with. I would like to purchase it from you
SOURCE: I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
Testimonial: "I will try to update the firmware. Thanks !"
SOURCE: I have a Sony bravia KDL32 L5000. pressing power
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise
the power supply board is dead,do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping that this will help to solve the problem.....
SOURCE: Hi, i have replaced the
If the T-CON board is dead,you will see black screen (no picture) but you will see slight glow due the backlights is still on. Check the fuse and voltage on the T-CON board, dead main board will not be sending the voltage to the T-CON board.
But you are saying taht you cannot get any button on the TV to work, that will point the problem to be in the main board.
You will need service manual to really go in-depth troubleshooting.
You can download here for free: http://elektrotanya.com/?q=showresult&megnev=sony&megnev2=KLV-27HR3&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
