Question about Bush WS6671 28" TV
Occasional 'whistling/whining' from back of TV
There is a high pitched whistling sound from the back of the TV. It occurs after the TV has been switched on for a few hours. It is a similar sound to a 'worn' power valve from old TV times. I fixed that by tapping the top of the valve to discharge the gas (so I am told!) When I waggle the AV1 scart at the back of the TV the noise varies in pitch and sometimes stops altogether (although more often than not the noise comes back again. It is almost as though there is a whisker of wire shorting out. Sometimes it is louder and higher pitched than others. There is also a low pitched continual buzz (not a hum) from the TV but this is not loud enough to be annoying as you have to get quite close to the TV to hear it. It can get worse if the DVD is switched on but judicious manoevering of the DVD minimises the effect (electro-mechanical/magnetic interference possibly?) However if the TV is left alone the high pitched whistle goes away of it's own accord; usually after 20-30 minutes. The TV is just over 1 year old. Any ideas for a, preferably cheap, solution.
    Problem Solver:
  • 6 Answers
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Posted on Jan 31, 2007
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
I have a RCA projection TV. The picture and sound are fine. After the TV is on for a bit it starts a highe pitch whistle. The picture and sound continue to be fine. What is the problem and what can I do to...
Most likely the color wheel is starting to go bad adn when they do they get a high pitched whine sound coming from the bearrings on the wheel. Might want to look at getting a replacement before it quits. When they die you can't watch your tv till it is repaired.
thanks
Jul 22, 2011 | Televison & Video
I have a samsung hln507 and there is no picture. we start the tv, it has a high pitched whining sound, the fan and the color wheel are spinning, but there is no picture. after about 10 seconds the tv turns...
The colors wheel is dead.That why,u hearing high pitched whining sound.The colors wheel is spinning off of is motor axis and grinding it sides walls,that where the high pitched whining sound came from.Hire a tv Tech. for the colors wheel changing,because it requiring to take out alots of the machanicals parts itself,before u can come to the colors wheel itself to change it.
Oct 16, 2010 | Samsung HLN507 50" Rear Projection...
1994 ranger in 3rd and 5th gears, it has a loud whine to it.
Mine has a high pitched whistle at high rpms and I can't figure it out. But mines def not the tranny. I'm thinking it's a vacuum line somewhere. It's a 97 2.3l manual. The colder it is the louder...
Apr 12, 2010 | 1994 Ford Ranger Supercab
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
High pitched whine/whistle on startup - 2003 Toyota Sienna
I have the same problem like yours but what i did is to replace the alternator and now its so quite no more high pitched sound. You may used belt stress fluid but its only last for few seconds then sound comes again. I replaced it with refurbish part alternator.My sienna 2005.
Dec 21, 2008 | 2003 Toyota Sienna
Televison & Video Logo
277 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
