Question about Microsoft Windows 98 for PC
How to install windows 98 in ms-dos based
How can i solve the problem
  • Anonymous Dec 01, 2008
    installation of windows 98
  • 849 Answers
Boot your system with bootable 98 cd. i will start automatically win98 setup.
Posted on Nov 29, 2008
  • 734 Answers
Go to the windows(as your windows backup stored) directory and
just type setup and press Enter
write me for more help,, tell me where is your windows 98 backup is --in CD or computer HDD.
Graphics in c not working in my pc
Uninstall Turbo C++
Restart your computer
Reinstall Turbo C++
Try your program, again.
Jul 30, 2010 | ASUS M2N-MX Motherboard
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
Mar 16, 2008 | Computers & Internet
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows 98 for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
