Question about iRiver H10 MP3 Player
Iriver doesnt play songs any more...
Hey. My iriver H10 does not play any songs and does not synchronize with Windows Media Player. Also i cannot delete songs from the player or upload new ones (which is pointless at the moment as cannot listen to them)!!! It also tends to freeze quite a lot these days... what do you rekon..? Cheers!
I had the same problem and i fixed it by updating the iriver firmware
Posted on Mar 18, 2007
Iriver, H10 , system files missing
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Sep 16, 2008 | iRiver H10 MP3 Player
Freezes
Reset by removing and reinserting batteries
-Tha Mp3 Doctor
Sep 03, 2008 | iRiver H10 MP3 Player
H10 6gb
-Tha Mp3 Doctor
Aug 26, 2008 | iRiver H10 MP3 Player
Iriver h10
http://www.iriver.com/product/p_detail.asp?pidx=71
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 20, 2008 | iRiver H10 MP3 Player
Iriver Troubles
Delete the playlist and try to re-add using windows Media Player - make sure EVERY song in the playlist is in the right format
Mar 31, 2008 | iRiver H10 MP3 Player
Iriver h10
During instaling new Firmware there is option for FORMAT disk, thus all data will be deleted and disk reformated
and then also can try to chech errors on disk by standart windows properties
Jan 29, 2008 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
Iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Mar 28, 2007 | iRiver H10 MP3 Player
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
80 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
