Question about Pioneer Audio Players & Recorders
Pioneer rx590 double stereo cassette record button jammed causing both cassette drive not to play.
The cassette players are not functional
Posted on Dec 19, 2008
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
675 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
