Question about Kenmore 44102 Front Load Washer
Kenmore Front loader Washer Problems
Kenmore washer model # 48102 will literally spin out control during spin cycle. I check the level and everything is level. Adjustd the front legs but the washer continue to spin out control. Need help.
  • 1 more comment
  • Anonymous Dec 13, 2008
    Exact same thing happening here. Sounded absolutely terrible. Went racing into the basement to find the washer had walked about a foot and was taking a table and the dryer along for the ride.
  • Anonymous Jan 18, 2009
    I also have the same problem no matter what spin cycle speed I set it at. Any solutions yet?
  • tvose Apr 22, 2009
    In the spin cycle it sounds like the drum is banging on something and it's extremely loud. I'm worried that I will damage it if I keep using it.
U need to remove the shipping bolts, found in the back of the washer, 4 long bolts used to hold the drum in place while transporting. we had same prob
Posted on Feb 04, 2009
  • 4 Answers
Hi, I got this exact Kenmore washer from Black Friday.  They finally installed last week and the vibrations were way out of control!  I looked around the machine and inspected the installation manual after spending hours leveling the thing and finally figured out that most likely cause is the foam shipping part at the bottom of the machine.  I called Sears to come back out since I have a pedestal screwed on the bottom, trapping the foam.  They came out and didn't think it was the issue.  I asked them to take it out anyway, and sure enough it worked.  For the first time my machine is working just the way it should...I wonder how many washers were installed this way?
Tip: To confirm that this is the problem, if you push down on the drum from the inside of the washer, you should be able to make the foam squeak...there's your problem!
Posted on Feb 08, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 16, 2011 | Kenmore Washing Machines
Kenmore front load washing machines knocks
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader Model 48102 will not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Mar 14, 2009 | Kenmore Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
608 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
