Wus hooking up my car amp, had the earth in then went to put the power in an as soon as it touched it sparked an smoked. how to fix it?
  • Terry Rodgers Jr.
    Terry Rodgers Jr. May 11, 2010
    need a little more than that mitchdog,(what i'm saying is did it burn the insulation off the wire)or did it just spark a little,let me know .thanx for using fix-ya!!!
  • jason May 11, 2010
    you do realize it smoked , and if you do not know anything about electronic components or testing them or identifying them, then you will not be able to fix it , nor will i or any one else be able to help you fix this
    can you perform these tasks?
  • 73 Answers
It depends if you have blown the amp first check all fuses then make sure your power is disconnected and the earth is very good, tight ect. the reconnect everything and if it still doesnt work try a replacement amp and cables
Posted on Nov 29, 2008
I have a memphis mcd 1000. It started smoking and blew both fuses. I replaced the fuses now when I hook power to the amp sparks real bad like the power and ground are touching
I hate to tell you this, but you have something major. Shorted. Check your wires and conections with a meter. The bad news. Is your amp may be a goner.
Apr 28, 2015 | Memphis Car Audio & Video
My orion 2150sx is smoking when powered
No some one did not have the speakers hooked up properly ,End probably went under the OHM,Rateing for the amp, Or use the wrong OHM SUb on it, OR if they used a Dual voice coil sub,Didn,t have it wired up Properly.
Oct 30, 2012 | Car Audio & Video
The thermal and power lights are on soon as i hook the amp up to the power
check your connections, this usually indicates that you have a short circuit but also make sure that your earth strap is securely fastened to a clean metal fixing.this could well be the cause of your problem.
May 05, 2011 | Rockford Fosgate Punch P5002 Car Audio...
I changed the battery and negative treminal for my 1995 ford escort and as soon as I hooked up the battery it blew the 100 amp main fuse under the hood. I replaced the 100 amp fuse and hooked the battery...
At a guess, I'd say that you have got the new battery in back to front. This means that you are hooking the earth wires to the Positive side of the battery.
Mar 24, 2011 | 1995 Ford Escort
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Gee I would think that it is kind of obvious; your amp is blown. Just because it doesn't blow fuses doesn't mean much. If you hook the power up to the ground input and the ground to the power and then turn it on you pretty much toasted the amplifier. If you don't know why the amp is smoking, but you're trying to fix it yourself, you are basically telling me that you have no business doing so. I have been an installer for 15 years and even I am not dumb enough to try to fix a bad amplifier. Do everyone a REALLY big favor; stop messing around with something that you don't understand of have knowledge about before you hurt yourself.
Mar 16, 2008 | Legacy LA838 Car Audio Amplifier
Trying To self Repair SoundStorm 700.2, Replaced Parts and still having problems
The power transistors are shorted out and must be replaced. If you contact JL they will fix it for a flat rate. That amp is well worth it.
Sep 22, 2007 | Jl Audio 300/4 Car Audio Amplifier
Blown part in amp
your protection is dead chenge releais and go
Jul 22, 2007 | MTX Thunder 81000D Car Audio Amplifier
Amp not working
What's the problem? It's not unusual to get a spark when you connect power to an amplifier; there are capacitors in the amp that will charge. Is the amplifier not working?
Jan 29, 2007 | Jensen KA3 Car Audio Amplifier
20 people viewed this question
