Question about Gigabyte GA-8N-SLI Motherboard
Problems during boot
On GA-8N-SLI windows is successfully installed but sometimes while booting it is stuck on the windows screen and loops that can last for hours. Sometimes it is fine when the boot process is completed sucessfully.Even the bios is updated to F6 the problem continues. Pls help me...
  • Pradeep Dyal Jan 20, 2007
    How can a newly purchased m/b contain low cmos battery? But I am sure that the bios is responsible for such thing.
    President:
  • 2,961 Answers
This is windows unable to get to passed the lower bios memory before windows takes over with the normal memory. Check your cmos battery is'nt low, or reset the bios JBAT1 terminal from pins 1-2 to 2-3 then back again as the loop could be corrupt bios or a peice of hardware that cannot be started.
Posted on Jan 17, 2007
Computer won't start. Message keeps saying " attempting to restore Windows" but seems to be in a loop. What can I do
I hope this will help
Method 1. Reset your Windows 10 PC
Navigate Start > Settings > Update and Security > Recovery > Reset this PC.
Then Hit on the Get Started button just below the option to fix Windows 10 'Restoring your previous version of windows' stuck issue. During the process, select Keep my files option will allows you to keep all your personal data safe.
Method 2. Perform a System Restore or Startup Repair
1. Download Windows 10 media creation tool and create a Windows 10 installation media.
2. Boot or start your computer from the Windows 10 installation media.
2. In the Install Windows page, tap 'Repair your computer' to start the Windows Recovery Environment.
3. In the Windows Recovery Environment, on the Choose an option screen, click 'Troubleshoot'.
4. Click 'Advanced Options' and then click on 'System Restore' or 'Startup Repair'.
Then follow the on-screen instructions to fix Windows 10 'Restoring your previous version of windows' stuck or loop and restore the computer to an earlier state successfully.
Method 3. Clean install Windows 10 with ISO image
If none of the above methods is helpful, you can try to reinstall Windows 10 with ISO image file. Just download Windows 10 media creation tool. Try it to download Windows 10 ISO image file and burned it to bootable DVD or USB flash drive. And then clean install Windows 10 on your PC. It has helped most users to fix Windows 10 stuck at 'Restoring your previous version of windows' loop.
Method 4. Restore Windows 10 using previous backup image
The above methods are all the possible free solutions from Windows 10 settings to fix Windows 10 stuck at 'Restoring your previous version of windows' loop. Actually, at most times, they might not help due to certain reasons. So we strongly recommend you to backup Windows 10 system with EaseUS Windows backup software. It can help you easily and quickly restore your system from the backup image without losing anything when a disaster happens unexpectedly.
Feb 08, 2018 | Computers & Internet
XPS M1330 laptop is stuck at update 3 of 3. It is in a loop between the update and restart.
Search Results
Latest Vista Update stuck in Stage 3/restart loop - Microsoft ...
https://answers.microsoft.com/...update/...update-stuck...3restart-loop/2f70b13c-9db4-...
Jul 26, 2009 - I have Vista Business system on a Toshiba notebook, latest Service Pack and with allupdates. ... I just booted it up to find the Stage 3 page of a Windows update. ... Have tried using F8 to get last good installation, and to stop auto restart, without success, it just keeps returning to ..
Mar 21, 2017 | Dell XPS M1330 Notebook
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
My computer is blue screening when i first load it up windows 64 bit home edition gigabyte k8n sli motherboard
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Mar 30, 2011 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Gigabyte GA-VM900M and Inno3D GeForce 7300
just reinstall the operating system.
dont forget to vote
Sep 16, 2009 | Gigabyte GA-VM900M Motherboard
Possible motherboard issue???
I suggest you should repair your OS. Just insert your winxp cd installer and boot from cd.
there is Rapir option at windows installer option. just repair it and you will get your windows work again in approx. 30 minutes :D
br
Aug 06, 2008 | Gigabyte GA-K8NXP-SLI Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
CANNOT SET UP SLI MODE
So it sounds like you are able to enable SLI mode, but once you do, you have no video output (upon reboot). The most likely problem is that it's now in SLI mode, but your monitor cable is hooked up to the wrong video card; try changing it to the other video card, and see if you have output from that one.
Sep 19, 2007 | Gigabyte GA-8N-SLI Motherboard
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
Will not display anything when booting up.
does your motherboard has a builtin video card? u probably connected your monitor to it which supposed to be connected to your new installed video card.
Jan 15, 2007 | Gigabyte GA-8N-SLI Motherboard
Gigabyte GA-8N-SLI Motherboard Logo
127 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
