Question about Kenmore Elite 45986 Front Load Washer
Washer tub slowly fills with water
After every 3 or 4 loads, my front loading HE3t slowly fills with water. Water seems to be coming from grey rubber gasket around door. (There's a little slot where the water is dripping from.) This is very sporatic; I can't find anything that could cause it!
  • 5,911 Answers
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Posted on Mar 24, 2007
WHY IS WATER IS LEAKING FROM WASHER?
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
Jul 30, 2014 | LG WM2016CW Front Load Washer
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Apr 25, 2009 | Frigidaire GLTF1240A Front Load Washer
Tub filling with water after cycle is finshed
If your washer fills with water, usually slowly, after the cycle is over you have a inlet water valve which is not shutting off completely. LG usually uses a separate valve for the hot and cold. If you turn off the valve where the hose comes from the house and observe for continued water fill, first one, the reopen it, then shut off the other you should be able to see which (hot or cold) is the culprit. If you post your exact model number I should be able to list the part numbers for you. The inlet valves I am speaking of are the part where the hoses connect onto your machine.
Nov 07, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Kenmore elite he3t washer
remove fill hoses at wall and washer ends look for a screen in hose at faucet end and 1 in washer fill valve pull and clean them be sure to reinstall screens before reconnecting..also fluch hoses out after reconnecting to faucet end and before reconnecting to washer to flush any trash/sand that be in them
Aug 15, 2008 | Kenmore Elite 45986 Front Load Washer
Water Leak
While I do agree with eagle338 that water could be leaking from the fill hoses and the pump area, the rest of the instructions apply more for a top load Maytag washer, instead of the front load Whirlpool washer you reported.
Most likely you will have a hole in the front boot area (grey rubber seal around where the door seats). If you find such a leak, send me a note back and I'll write you up a how to to change it out.
The second most common source of leaks come from holes in the tub. This is the white outer part that holds most of the water in the machine. You will easily be able to see it when you remove the panel as listed above in the clarification instructions.
On rarer occasions, you can have something stuck in the fill tube that goes from the dispenser to the tub. Somehow small items become lodged in there. There will be a water inlet about the 10 o'clock position of your boot (grey rubber seal). Probe gently in there with your finger to see if a sock or similiar item got spun into this area.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3t water fills by itself! with door open too! doesnt always drain fully
If you tip the machine back at an angle, you should see a clear plastic sausage shaped thing with a plastic tube coming from it, you will need to remove the plastic thig (pressure vessl) and clean it out.
Nov 30, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
447 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
