Tv will not stay on
Turn on power and tv warms up and freezes about every 15 seconds.
  • ronaldwlong Nov 29, 2008
    Samsung DLP HLR5067W tv Plug in, turn on, tv lamp lights and warms up, tv stays on about 5 seconds and then freezes for about 10 seconds, audible signal indicates that the tv has been turned on (the lamp does not go out) plays about 5 seconds, freezes for about 10 seconds, and repeats this indefinitely.
  • 849 Answers
Unplug the tv and stay for 5 minutes, then re plug it. if it works, ok. otherwise check the signal. signal coming from the cable might gives such problem or ask your cable operator.
the condition you specified shows that tv has no problem.
Posted on Nov 29, 2008
    Sergeant:
  • 276 Answers
Its the problem of DMD board of the tv is gone faulty.or the digital board faulty.as its not quite easy to get it repaire but replacing will cost u near to $600 for this.after replacing it will work.as this is happening due to the current passing through the tv when you power ON is not been handled by the board so the board needs replacement.
  • 734 Answers
Problem is occured due to fault in adapter ,, it supplies more voltage than needed.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your description could indicate two possibilities:
  • heat related problem; and/ or
  • protective mode. The unit senses a problem and to prevent escalation automatically shut down the unit.
Often, there would be additional indicators such as blinking lights on the front panel. These blinks would, at times, have a sequence which could point to probable fault, where to start diagnosis. Additionally, knowing the brand and model (chassis number) could narrow down probable causes based on known issues and incidents.
Just a start, do postback brand & model, how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 291 Answers
For first u just unplug the tv for nearly 24 hours and then replug it that will reset all the settings.and the another cause could be due to the ovel voltage passed through the main board that needs to be checked and main proper.the capacitors should be checked on the main board and the faulty 1 should be replaced.
  • 1,183 Answers
Could you give us the model number for the TV and since when is the TV having the problem
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Nov 29, 2008
    I'd definitely give a call to 800-SAMSUNG to see if one of the techs can determine the problem. I don't have enough information to troubleshoot that particular symptom.
    Thanks
    proton
Galaxey 2 tablet freezes
Press and hold the power button for 10-15 seconds. This should hard reset the tablet.
Dec 08, 2012 | Samsung Galaxy Tab Tablet PC
Tv is powering off and on randomly. Will stay on for 15-20 min initially, then will turn off and back on every 10-20 seconds.
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Oct 03, 2011 | RCA 20F514TD 20" TV
TV won't stay on
I would suspect either some capacitors failing in the power supply, a bad solder connection, or a component drawing too much current. Replacing the power supply may fix it.
Apr 02, 2010 | Sylvania LD370SS8 37 in. LCD Television
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
Hd channels are freezing up sound stays on just
Hey there, raeraekub! In order to assist you with this, I need to get a full understanding of the situation, so I'm going to ask you a few questions. First of all, is this issue still happening? If it is, try unplugging the receiver's power cord from the wall for 15 seconds then plugging it back in. If the problem continues, let me know what type of connection you have from the receiver to the TV. What type of TV do you have? With the DVR issue, is the freezing happening in the middle of watching a recording?
Oct 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
May 11, 2009 | Sharp LC-13AV1U Television
My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
TJ@streetkidssoftball.com
Sep 28, 2008 | Televison & Video
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
