Question about GE 28021EE2 Phone
Will not ring
I have registered the phones, i have set the ring volume to high but it will not ring. The old phone rang on that line with no problem but can not get this system to ring. We know someone is calling as the fax machine on the same line rings. Otherwise the phones work good.
  • 1 more comment
  • safari909 Dec 14, 2007
    hi..
    iam using the same phone. could not hear the ringer tone when somebody calls me. but i could hear the messages.
    incoming ringer is not working.
    please suggest me with the solution.
  • Lisa Hartnett Jun 09, 2013
  • Anonymous Mar 15, 2014
    phone does not conect to line and just rings
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
Posted on Oct 17, 2007
SOURCE:
My phone will not ring anymore - neither the handset or the base unit. There is no menu button to push. HELP!
You can select the ringer volume to HIGH, MEDIUM, LOW or OFF on the handset and the base unit separately. The factory preset is HIGH. If set to OFF, the unit will not ring for external calls and will ring at the LOW level for intercom calls.
1. Does the phone dial out ?
If yes go to next question. If No check line.
2. Do the displays flash when the call comes in ?
3. Is the volume setting too low.
either way refer to manual attached here Panasonic KX TG5100M Operating Instructions Manual
Mar 11, 2016 | Panasonic KX TG5100M Cordless Phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
I cannot hear my phone ring. It is set to high
Look for a setting that changes the ring from vibrate to ring. It's a setting different from that of ring volume.
Dec 11, 2009 | Cars & Trucks
Make the ringer louder I cant hear the phone ringing
Hello. From the User Guide:
1. Press Setup.
3. Press > to select one of the options: Soft, Loud, or Off.
4. Press OK.
1. Press Setup.
3. Press > to select one of the options: Medium, High, or Low.
4. Press OK.
For your reference, here is a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Thanks for using Fixya.
Sep 29, 2009 | HP Officejet 4355 All-In-One InkJet...
Phones do not ring
Check the DND button- it's the far right button on the top row. If DND is not on, your ringer volume is probably turned down.
The volume is set independently per line. To set the volume:
1. Press Conf, then using the dialpad, press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2. Press one of the VOLUME buttons to increase or decrease the ringer volume.
Apr 01, 2009 | AT&T 954 Corded Phone
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
I HAVE A PANASONIC PHONE (KX-A332CE-B) AND THERE IS NO RING TONE ON INCOMING CALLS. I CAN CALL OUT AND THE LINE IS OK BECAUSE THERE IS A RING TONE ON INCOMING CALLS WHEN I USE ANOTHER PHONE. CAN YOU HELP...
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Feb 24, 2008 | Lands Phones
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
My Sony ericsson k800i is not ringing in full volume
I had exactly the same problem and came to a conclusion.
When you are playing in your music player at the same time it's playing use the volume keys on the top of the phone.
I hope this helps
Jul 24, 2007 | Sony Ericsson K800i Cellular Phone
GE 28021EE2 Phone Logo
149 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
