If I disconnect ac connection the laptop shut down.
If you are saying your laptop shuts down when you remove the power cord then that's a sign that your battery is dead.
Batteries only have a useful life, then after that they have to be replaced. Once the useful life is up, most times the battery will not take a charge.
Some batteries will take a charge and say they are at 100% but as soon as you remove the power cord it doesn't take long before it is drained at 0%.
SOURCE: The cursor on my AUSUS U50A is frozen. All other
Hi
Thank you for your query it would seem the touch pad has been locked
on most Asus laptops the key to unlock is to press the fn key + F6 key (the F key will have a rectangle on it and a finger or hnd pointing to it).
Please try and advise of the outcome
I hope this has been useful
SOURCE: Toshiba laptop reboots when on AC Power
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
