Question about ASUS P5P800-VM Motherboard
Motherboard power problem due to atx 12v cable
When the atx 12volts cable is connected to its proper socket, suddenly the motherboard P5p800-VM losses its power(the fan of the microprocessor turned-off), i tried to replace the power supply knowing it could be the reason, but still the problem is the same,, when the it is disconnected from its socket, the fan of the of the microP turned-on. we have 5 same motherboards with the same problem...please, i cant do it alone, and nobody's here to give a hand, i am an incharge of a laboratory, i am new to this...thank you...
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    Are you sure this is not an intelligent power supply?
    When you short the power-on jumper (hit the button) does the computer come on?
  • ASUS Master
  • 4,806 Answers
Sounds like your in the ****, this could be a nuber of things, if you could phone me i would be able to help you out, typing all of this would be a very tedious and time consuming, plus i live in the UK
its up to you
regards
Posted on Nov 29, 2008
Asus p5p800-vm MOBO, when i power on the CPU the monitor is no display and the red light who's booting the HD is powered on.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 10, 2011 | ASUS P5P800-VM Motherboard
Asus P5P800-Vm
This problem is either your power supply, the mother board or the processor, try using a different power supply first and see what happens. Take the processor out of the socket and take it to your local pc store and ask if they will test the processor for you, if all are ok then it is *********** board is at fault and will need to be replaced.
Feb 10, 2010 | ASUS P5P800-VM Motherboard
ATX
there is no problem.its just the size...
Jan 04, 2010 | ASUS P5P800-VM Motherboard
System won't turn on but when i pushg down on one side of the power suply connectore the fan starts running but computer stioll won't turn on it used to boot up then opne day stopped
It sounds like you have a faulty connector - I would return the item under warranty. Otherwise, if it is out of warranty, you will have to source a new motherboard.
Nov 23, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
Instalation of a P5P800-vm motherboard
i have the motherboard manual for you if you need it. email me at fifthw4life@yahoo.com
Nov 18, 2008 | ASUS P5P800-VM Motherboard
ASUS P5P800-VM motherboard - LED on; fan on; no monitor output
if it has an external video card reseat it or clean the gold contacts
Nov 06, 2008 | ASUS P5P800-VM Motherboard
Sudden Shutdown
Hi, I am Sanja and will try to help you.
Try to remove battery from your motherboard, and power cable from computer case. Leave it for about minute, and then return battery, power cable and try to turn on the PC.
You should have no trouble in identifying battery, it is pretty much standard, if you have more questions please do post them
Regards, Sanja.
Sep 15, 2008 | ASUS P5P800-VM Motherboard
LAN problem between Belkin modem and P5P800-VM MoBo
When you connect the pc to the router does the port number where that pc is connected is there any light on it? if there is check the IP address of the pc.
Click Start>RUN>type CMD click OK>type ipconfig on the command prompt if it says disconnected try changing the ethernet cable.
If you already receive a IP address that's good then try getting online.
May 03, 2008 | ASUS P5P800-VM Motherboard
ASUS P5P800-VM Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
