Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My left speaker is not working on my macbook 13"   externals do work.
I reset my PRAM and NVRAM during start-up, and it completely fixed the problem.  Thanks to the support of the people at apple.com, they suggested troubleshooting before I went out and bought a new speaker.  The best part was that it was free of charge.  Thank you for your offer though.  I'm sure you're going to suggest this to the next person with the same problem and charge them for this suggestion.  I hope it all works out.
Sincerely,
E.
Posted on Nov 30, 2008
Macbook - lost left speaker, data, and camera. SMC reset either way didn't fix. Running external monitor which does work
You may have to reset the PRAM. Note: To print these instructions, open Help Viewer's Action pop-up menu (looks like a gear), then choose Print.
  1. Shut down your Mac.
  2. Locate the following keys on the keyboard: Option, Command (?), P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on your Mac.
  4. Immediately press and hold the Option-Command-P-R keys. You must press this key combination before the gray screen appears. Continue holding the keys down until your Mac restarts, and you hear the startup sound for the second time.
  5. Release the keys.
Resetting PRAM may change some system settings and preferences. Use System Preferences to restore your settings.
Happy 2015!
May 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The volume settings are all on and the speakers are not muted but I can't get any sound. How can I fix it?
If you are using external speakers check that all the cables are plugged in correctly. Is there a power cable? is the input cable connected to the headphone port on your macbook?
Aug 15, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My computer speakers don't work - they do if I plug them into external speakers.
The fact that it works fine with external speakers means that the soundcard works fine.
Make sure that volume isn't too low by holding the FN key and then tapping the F5 or F12 Key to reach a higher volume (depending on what the layout of your keyboard is)
If still does not make a difference, chances are that the internal speakers have developed a fault. You would need to get someone to open up the laptop and have a look. Would not suggest you do it yourself unless you have done before, as they components are more sensitive than a Windows XP one.
Hope that helps, Pls rate the solution
Nov 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The volume does not work on the built in speakers but does work for my normal head phones or plug-in speakers
Go to the Apple menu (Apple icon, top left) > System Preference > Sound
click on the output tab and make sure that the internal speakers are selected. If they are selected and you still have the same issues you will need to call AppleCare 1-800-275-2273
Nov 04, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook got wet and now the speaker wont work !!!!
The audio port section and battery internal connector are both is same place.so may be there is a sort of connectivity happening.dry the laptop for few days and then use.hope the issue will resolved.
Mar 16, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
No sound from external speakers using macbook 13
go to system preferences and select sound button
check out the output tab int window, if output volume is disabled it means there is some problem with hardware. I had a similar problem it turned out that speaker wires where disconnected.
Jul 02, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook 13" intel core 2 left speaker not working
In system preferences/sound make certain that your balance is set correctly.
Nov 29, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Monitor non functional
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Aug 02, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
60 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
