Question about Hoover Vacuums
Hoover SteamVac F7222-900 steamvac Brushes do not spin. Looked at filter as per manual instructions but it was free of lint. Need to fix it, help please? Vacuum was used less than 10/12 times
  • 8 more comments
  • eddio49 Nov 29, 2008
    After original recomendations about removing and cleaning brushes my Steamvac's F7222 900 brushes still do not rotate.
    Could it be the turbine gear? and if yes how I disasemble it to get there?
    I have removed 5 screws but still can't get the part to come out.
    Wife is driving me nuts and checkbook is tooooo thin
    Everything works but the brushes that do not spin.
    We used last weeken to clean the stairs with hose attachement and worked.
    When we tried to do tha carper the brushes will not spin. It makes noise so there is not an electrical problem, the motor seems to be working.
    My closest authorized dealer for warrnaty is about 50 minutes away and the shop owner says "not all is covered" so why bother I do not even know where my wife saved the receipt :-(
  • eddio49 Nov 30, 2008
    I received "advice" to change TWO belts, well as far as I understand this one does not have any belts.
    I JUAST NEED TO KNOW HOW TO REMOVE THE ASSEEMBLE SO I CAN GET TO THE TURBINE AND FIGURE IF THAT IS THE PROBLEM.
    PLEASE!! do not advise me in testing the fuse(?) or maybe cables are loose (the machine turns on and the noise shows it is not an electrical problem) or like somebody said to take to a repair shop (I can do this last one ALL by myself and without any advise)
    Thank you for your time
    Eddie
    How do I get to brush motor?
    Boscia,
    Thank you for the suggestion, that is exactly what I am trying to do (although I read somehwere this one does not have belts?).
    Problem is I can get out the hood assembly (large plastic cover that has the hoover logo), I removed all the screw I could see plus snaped out of the holes the fasteners at the rear part, took out the plastic knob that is of rthe brushes on off position but i just cant go any further. It seems it is attached somewhere else but can see it and do not want to apply any preasure if I am not 100% sure.
    HELP PLEASE!!!!!!!!!!!!!
    good wrench
    thanks for the suggestions. tested both and problem still there.
    Thing is I can get out the hood assembly (large plastic cover that has the Hoover logo), I removed all the screws I could see plus snaped it out of the holes that fastens the rear part, took out the plastic knob that is for the brushes' on off position but i just can't go any further. It seems it is fastened somewhere else but can't see where and do not want to apply any preasure if I am not 100% sure.
  • eddio49 Dec 02, 2008
    lancer721
    Thank you for your suggestion but no cigar!
    I need to remove the hood assembly and just tried every way but I cant. It seems it is fastened somewher that I cant see, I am just beyond fuming with this machine.
    If anybody knows how to remoc=ve the hood step by step or direct me to a website where I can see it I am pretty sure I can open the turbine case and then figure out if there is a belt or not and if the turbine works (I think it does) or not.
    Please DO NOT MAKE ANY other suggestions since I can't open the darn thing.
    Just let me know how to do it.
    Many thanks to all that provided the smart answers
  • eddio49 Dec 04, 2008
    artiaco07
    Thank you for your opinion but I do not have a broken brush assembly, the full stem is there!
    That is the one of the first things I checked out.
    What I really, really need is to be able to take apart the hood assembly. I have removed the 5 screws I found snap it ou from the rear fasteners but just cant get it to coome out :-(
    Any other advice PLEASE DON'T just the assembly.
    Thanks!
  • eddio49 Dec 07, 2008
    No it did not help!!
    And nope the brush is not broken
    And yes thsi website sort of stink and I feel I have been cooned for $10 US :-(
    BAD, BAD, BAD ..................
  • 3 Answers
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
I followed Mark406's advice from the above post and easily fixed my Hoover Legacy Steamvac. The turbine was stuck and just needed to be turned and freed up. Great post Mark406, good easy to follow instructions. This repair only took about 30 minutes and I was finished. My only gripe is that this can happen so easily in the first place.
Posted on Oct 05, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A common problem on most versions of Hoover with turbine system especially those that are not often used. Pls reference:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 65 Answers
The brushes spin by the vacuum that it creates.There is a sliding lever where the handle pivots on the right side make sure that it slides back when you release the handle.It may be stuck with dried solution.You can also remove the brush assembly and make sure they spin freely.I hope that helps and any other checks would require disassembly.Thanks for using fixya
Posted on Nov 30, 2008
  • good wrench Nov 30, 2008
    Before you take it all apart take out the brushes and get a screw driver and put it in the square that drives the brushes and see if it spins
  • 163 Answers
Try removing the case and locating the drive belt it may have come off track
  • Antonio Boscia
    Antonio Boscia Nov 30, 2008
    there are usually little plastic clips that are molded with the cover, take a small screwdriver and pry inward and upward pressure to the cover to pop it loose. it doesnt take alot as it is just plastic but you do need to put a little elbow grease into it.
    Novelist:
  • 166 Answers
The brush roll motor is most likely bad.
    Sergeant:
    Champion:
  • 338 Answers
I'm sorry to tell you that you have a broken drive brush. One of the brushes has a stem, and that stem is broken. See if you can remove the brush assembly - I believe it pulls straight down. See if one of the stems is a little longer than the others - maybe 1/4 inch. It should be an inch or so longer. The other part is stuck in the drive - look under the cleaner to see it.
Now for the bad news, the only way to fix the problem is to replace the entire brush assembly, which costs 25 to 35 dollars. I've searched high and low for the brush itself but have not been able to find it. Mine has broken twice (and I'm waiting on the second replacement).
Hope this helps.
Posted on Dec 02, 2008
    President:
  • 2,712 Answers
Since you said that you just used it a couple of times, it must still be under warranty. Best get it replaced under warranty.
If its not under warranty, then check the fuse first, check the gears. If they are OK, it is most likely a fault with the motor, which will need to be replaced.
Posted on Nov 29, 2008
  • 734 Answers
The most common problem electrically lies in the main switch and the power cord. Almost at no time in the past three years and working for 4 hotels have I had to replace any motor or board component for them. Take out the handle from the bag housing and use your volt meter/circuit tester to test the main switch, if that and your power cord are good, then you might have a bad fuse, which is located on the brush side of the main chip board.
  • futureloginn
    futureloginn Nov 29, 2008
    The brush roll motor is most likely bad (part #2036757). You will have to take it aprt and check it.
    Genius:
  • 3,422 Answers
HI,
they may just need to be cleaned! You can remove the rack of brushes by pinching the tabs on either side and pulling it out. The plastic is clear so you can see if the brushes and gears are gummed up with hair and carpet fibres. Rinsing usually works best. There are two more things to check if this doesn’t solve the problem. First, check that the switch for the brushes is set to high. Second, look under the clear plastic piece near the switch (it is removable). There is a small screen that collects lint and hair (like a dryer screen!). This is the air intake for the turbine that drives the brushes. Clean it off and your back in business.
    Sergeant:
  • 229 Answers
There has to be a belt to those brushes that is bound up or broken. Find the belt to repair.
  • 10,515 Answers
Your vacuum cleaner has two belts which should be changed at least yearly. V belts do not stretch, but the outside gets smooth from slippage. V belts don't run in the groove. They run on the sides, much like in a car V belt
Sometimes the brushroll control lever will break because it was forced.
To avoid forcing the brushroll control lever or height adjustment lever; (with power off) lean vacuum forward slightly on its nose to relieve the pressure on the wheels. You will find it is easy to move afterward.
Thnx.
  • 4,806 Answers
Probably the belt or direct drive cog
  • Lee Hodgson
    Lee Hodgson Nov 29, 2008
    Problem: Brushes won’t rotate during floor cleaning.
    Possible solution
    Dirty filter screen on bottom of unit
    Setting selector on OFF
    Move setting selector to ON
    If you say you cleaned the lint following the manual, then it is either and electrical connection to the brushes that has broken, or the motor has failed.
    Either way you cannot correct this problem yourself unless you know how to use an electric tester to the the continuity of the motor and the wires
    regards
Hoover SpinScrub brushes not turning
Hi There,
Here's a very helpful Tip that I've written that explains step by step how to diagnosis the Hoover SteamVac when the brushes stop spinning. This will also walk you through how to replace the brush gear turbine assembly if you find that this is the part that is broken.
If this was able to answer you question, and help you fix this, please be so kind and rate the repair helpful, or leave feedback. This is really what keeps Fixya experts continue to answer free repair solutions rather then just the premium ones that customers pay to have answered. Thanks for showing your appreciation.
Feel free to add a comment if you have any questions or need further help.
Here's the link:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Thanks so much,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Cleaning brushes will not turn. I have cleaned the filter
Hi There,
Here's how you can fix the problem of your brushes not spinning on your Hoover SteamVac:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
Hope that helps you,
Chris Jones
goVacuum.com
Apr 25, 2010 | Hoover F7431-900 SteamVac Vacuum
Brushes don't spin, brand new unit righr out of the box. lint filter is clean ... speed is set to high ... brushes are snapped in properly.
There should be a switch on the head of the unit. Its probably in the brushes off position. I think its by the spin brush indicator on the left hand side
Jan 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not turn
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Clean inside of brushes
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose2_bing.gif with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If your brushes still wont spin, you may need to replace the brush block itself. Check the model number on your SteamVac which will be located on the back of the Steamvac on a stick with model information. GoVacuum.com does carry ALL of the SteamVac Brush Blocks on our site if you need to buy a new brush block.
Here's a picture on how you can remove these clips;
If this does not fix your problem, there are a few other problems that could be causing this.
Feel free to call me, or email me if you have any questions about your SteamVac, I'm more then happy to diagnose the problem overthe phone / email.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
1-866-468-2288
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover F745 900 steamvac brushes will not spin.
If you are handy with a screwdriver undo the casing to access the roller. Once open usually about 4-5 screws you will see that the drivebelt ( rubber band ) has broken. This is the piece you need to replace. Usually most electrical store selling cleaners have these. Take the piece along or get the part number from the manual and replace it yourself. Cheaper than having a tech do it at $90 an hr plus the $5 part
Jul 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Vacuums Logo
1,013 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
