Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
While not in operation dishwasher slowly fills up.
Kenmore Elite Dishwasher: Model 665.16952. While not in operation it slowly fills up. It appears to be a leak. Water comes in through a port on the left side of the dishwasher -- approximatly 6 inches from the bottom and 7 inches from the back. The water comes in at a very slow trickle, but enough to fill the bottom between uses. This just began to occur in the past week. To get rid of the water we have been pressing the cancel/drain button. We have run the dishwasher daily and the problem appears to be consistent -- occuring after each time we run the washer. The washer is 4+ years old and we have never had any other issues with it.
Water valve is clogged try to turn your valve to dishwasher under sink
Posted on Nov 29, 2008
What does E22 mean on the Kenmore Elite dishwasher
E22 means no fill or slow fill. Remove your water in hose and check that the screen isn't clogged.
Jul 19, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
The dishwasher soap in my kenmore elite dishwasher is not dissloving and as a result my dishes are not getting cleaned. any suggestions?
Check to see if it is filling with water and not draining it right back out. Give model number so I can look for a diagram to repair. Just fixed mine as it was doing the same thing.
Dec 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Dishwasher won't fill
Not likely an air lock. When plumbing work is done the pipes ge shook up and then particles plug up the screens on these and washer and faucets. I would make sure the over flow float is properly working and then check the screen on the fill valve. Could be a coincidence and the valve failed but that is my last choice in this case. Eric
Sep 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
145 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
