Question about ViewSonic N2060w 20 in. LCD Television
My Samsung 42"DLP displays wavy lines when connected to DVD
My television's picture is beautiful when viewing television but when a DVD player is connected, there are wavy lines that go across the screen.
The DVD still plays but the picture is very wavy.
I have tried 3 different DVD players. A Sony, An Emerson and a Panasonic.
I have also tried using both the RCA video connections and the S Video ports all with the same result.
I believe it must be something with the way my tv processes signals from a DVD player. Does anyone have any ideas?
premtech
  • 934 Answers
SOURCE: Viewsonic n3250w LCD-TV
That chirp indicates a feedback on the secondary transformer in the switch mode power supply and needs to be either repaired or replaced. A good shop can have this one back up in an hour or so - assuming they have the parts on-hand... If they have to replace the SMPS you'll naturally have to wait a few days. Most shops don't have such specific parts on-hand and will have to order it.. Replaced an entire SMPS for an Akai recently with the same symptom, chirping. Turned-out to be the regulators and two MOSFET's. A MOSFET is a metal oxide semiconductor field effect transistor.. In laymen's terms a switching gate. But below the two MOSFET's, when they went thermal they burned the board and several small traces which could not be bridged. The SMPS was $70.00 plus shipping, and you're probably going to be somewhere in that ballpark on this too if the whole SMPS has to be replaced. Good Luck Bill
Posted on Jun 08, 2007
SOURCE: Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Posted on Mar 18, 2008
kevin000
  • 1847 Answers
SOURCE: Viewsonic VPW425 No inputs working
Seem like the power supply hav blow off inside the unit.
Posted on Jul 02, 2008
SOURCE: black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Posted on Sep 26, 2008
  • 105 Answers
SOURCE: laptop not connecting to tv
TV's do NOT accept all computer resolutions. You must keep trying the various resolutions of the computer until you find one that works.
I believe 1280x768 normally works for most TVs.
Posted on Apr 29, 2009
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
Wavy snow lines on samsung
are those lines appear in the screen either you hooked up a source like a dvd player and also during watching tv channel?.if so, locate the t-con board which is mounted covered with metal shield. tried first with re seating the LVDS cable connected to the board to fix loose connection, remove and then re attached to the connector terminal.hope this can help good luck.
Sep 07, 2012 | Samsung Televison & Video
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Nosignal when i power it on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are trying to view the DVD on the Samsung TV, you need to firstly connect the DVD to the appropriate connection on the TV.
Once connected, with a Samsung TV, you need to press the SOURCE button on the TV remote control to view any external sources such as your DVD player.
The ‘NO SIGNAL’ message would indicate there is no signal, if you have not tuned your channels in, this may be the digital tuner you are viewing. Press the source button whilst a DVD is playing in the DVD and see if an image displays.
Jul 16, 2009 | Samsung Televison & Video
Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Apr 18, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Fuzzy connection on my samsung DLP HLN567W
Try the DVD player on another component connection on the TV. If the picture is still distorted try another DVD player or something with component output. If thre picture is normal with another input device then the issue is the DVD player,
Nov 28, 2008 | Samsung HLN567W 56" Rear Projection HDTV
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
ViewSonic N2060w 20 in. LCD Television Logo
336 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
