Purchased a new lamp and not sure why picture is green
SOURCE: Green Hue once Lamp Replaced
I've heard of that happening before. If you have a component cable hook up check the connections first to make sure a wire didn't come loose. If other inputs and the TV menu happen to be green then the light engine may have failed. Contact sony for info as some of their sets are still covered under extended warranty. This link has more info about the subject as well.
the tv dude
SOURCE: mitsubishi wd62530 green tint on bottom of screen
If you used the exact replacement lamp then your tv has a defective light engine, call mitsubishi and make noise they might be willing to help with the cost- around $800 to $1200
SOURCE: Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
SOURCE: sony lcd projection tv picture has a greenish tint
this is caused by the optical block going bad and needs replaced sony had a recall for this problem though i think it is over you could contact sony customer service to see if they could help this repair is expensive
