SONY EXPLOD SHUTTING DOWN.
I HAVE A SONY EXPLOD 1600 WATT AMPLIFIER.I HAVE RUN 4 GAUGE WIRES FOR GROUND AND HOT .HAVE MONSTER CABLE SPEAKER WIRES.AND MONSTER RCAS .I AM ALSO RUNNING 2 SOLO BARRICK 12S.SYSTEM SOUNDS GREAT.BUT IT HAS A PROBLEM OF SHUTTING DOWN .BUT COMES BACK ON AFTER A MINUTE OR TWO.DONE WIRE EVERYTHING ON SPEAKERS EVERYWHICH WAY I COULD.NO BETTER WHAT SHOULD I DO.IT FEELS LIKE THE AMP IS GETTING HOT .DOES IT NEED A FAN MOUNTED ON TOP TO CORRECT THIS PROBLEM.THANKS FOR ANY ADVICE.
  • jbrooks625 Dec 02, 2008
    THATS ABOUT WHAT I THOUGHT MY PROBLEM MIGHT BE.I DONT KNOW WHY EXPLOD EVEN SOLD AN AMP THAT YOU COULD ENJOY ONLY HALF VOLUME ..GONNA TRY THAT FAN TRICK AND SEE IF THAT WILL SOLVE MY PROBLEM.THANK FOR THE ADVICE
Your amp is surely over heating try to turn the gain down and yes mount a fan blowing air over the heat sink.
Posted on Dec 01, 2008
Trick to reset pb1217x when protect light comes on?
if the amp is shutting down and the protect light is coming on you just have to let it cool down because it is getting to hot, sounds like you are pulling to many OHMS for the amp. if you are running your speakers bridged you can try running them unbridged (parallel) and that will drop the OHMS letting it run cooler. or you might have to try a different speaker/amp combination speakers might be to many ohms for the amp.
Jun 23, 2014 | Pyramid PB1000 MOSFET Bridgeable Amplifier...
How to connect wires to amp
Most amps have 3 places where you need to hook up wires to power them. the 1st is a ground wire that at best is 1 foot long and it goes on the ground or negative 12 volt connection then a bolt on the car you may need to sand off the paint for it to work, 2 a RMT or remote wire that is normally in the middle of the power and the ground connections the remote turns the amp on and off so it needs to go to the remote wire on the radio or a ignition spot on the fuse box - turns on with key on and off when you turn the key off , 3 the power wire is hopefully large 4 gauge wire and goes to the + 12 volt plug on the amp this wire has a in line fuse and goes to the battery and to the amp only. RCA wires go from the radio to the amp and are round and just plug in with no screws some factory radios need a conversion kit you can get at walmart for RCA wires. the speaker wires have some sort of mark or line to tell you what to put were like if you put the line on a negative on the amp you need to put the line on the negative on the speaker box to or it will not bass and could hurt your amp. ask me if you need anything else :) and please rate :/
Sep 04, 2012 | Blitz 1600 Watt 4 Gauge Amplifier...
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    Car audio
    If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
    Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
    Legend Amp hook up manual.
    Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
    Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
    Run the REM to your stereo power ant. Wire. if available.
    Run the GND to Metal Chassis Ground keep it as short as possible.
    Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
    This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
    There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
    Hope this helps
    Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
    I have an xploid 760 same amp wit ha 800 watt sub. eb=verything should work fin. but the same prob when i turn up the valume the overcurrent kicks on
    use a bigger ground wire for amp and protect mode will stop clipping and shutting amp off also make sure power wire and ground wires aren't the same size ground bigger .............if this doesn't help change settings on amp to lower power
    easiest way to set amp is (turn the knobs on amp all down turn up your system to the level you listen to normally and then set the amp knobs for bass turn knob slow to set properly but i think the ground needs to be bigger and maybe moved to a new location
    hope this helped
    Mar 03, 2009 | Sony XM-2150GSX Car Audio Amplifier
    Car amp blows 12 volt wire fuse
    the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
    Jul 26, 2008 | Car Audio & Video
    Speakers cut off when bass goes up...
    sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
    Jul 03, 2008 | Car Audio & Video
    Confused
    Hi jimmyjames,
    How do you have the wires hooked from the sony reciever to the inputs on the mtx?
     Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
    Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
    When you answer I may be able to tell you more.
    Oct 19, 2007 | Car Audio & Video
    67 people viewed this question
     Grubhead
    Grubhead
