I'm trying to install a new ignition switch and turn signal onto my motorcycle but I need the wiring diagram and/or service manual to do this!!
SOURCE: need a wiring schematic for the honda cb450 online
Here is a copy from Chilton's CB450, 1970 and above, hope it helps. I had to reduce it to monochrome in order to post it. It was 769K in grayscale.
SOURCE: when motorcycle warms up it starts smoking
id say its time for a new set of piston rings sounds like youv got a busted oil ring
SOURCE: 2002 Honda XR 250 R new clutch adjustment
No adjustments or measurements needed.. The key thing is the clutch plate installation sequence. If the outer plate is a fiber plate, then you need to be sure the new clutch has a fiber plate as its' outer plate.
Please rate this solution. Thanks brendat_30!
SOURCE: need to know how to set timing on 1989 xr 250 r motor cycle
The ignition timing on your bike is CDI based and cannot be changed. Absolutely no way to change it. Valve timing is a different matter and involves static timing marks on the OHC gear. If the bike runs at all then the valve timing is set properly as is.
Pleas rate this solution. Thanks!
SOURCE: need to reconnect tail lights,blinkers,stoplight 08 honda crf450x
CRF450x rear wiring is as follows:
Green/yellow stripe-tail light only earth
green-blinkers+tail light.Common neutral.
brown- tail light power
blue- right blinker
orange- left blinker
Make sure the neutral wire from the blinkers are connected on a single line to the green wire from the tail light.
I'm not sure with after market lights so if there is not a connection
for the earth there may be a screw point.If you can take the lense of
the light you should be able to see the connection points.
