Question about InFocus ScreenPlay 4805 Multimedia Projector
4805 Lamp & Remote
I was watching a DVD on my 4805. I left the room and when I come back there was no picture. I appears the lamp is not working. It only has around 300 to 400 hours.
I removed the lamp assembly and cleaned the filter screens and still have nothing but a blinking red light. Also, the remote will not cut it off.
Thanks for your help.
  • phaduman Dec 01, 2008
    wow! Happened to me on 29th Nov - 1st noticed blinking red lights (I believe 3 close-blinks repeating themselves after a short gap) turned off the video.
    I cleaned the filters etc and then re-powered the unit. Now after trying for a while, I get a consistent single blinks.
    What can it be, other than lamp hours? The unit is about 3+ yrs old with no more than 500hours used.
    Scholar:
  • 167 Answers
This symptom can be caused by a few different conditions. Do you hear the fans running? If not then possibly the over temp protection switch has failed.
or the lamp cover is not securely in place.
If the fans are running (you can feel air flow) then either the lamp has failed prematurely or the lamp power supply (ballast) has failed or you have replaced the lamp and failed to reset the lamp timer and it has reached it's limit which can be reset by pressing both the volume up and volume down buttons on the the projector simultaneously for 10 seconds.
This will reset the lamp timer.
SagerTronics
Posted on Nov 29, 2009
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus 4805, wont power up remotely
    the lamp has burned ot and needs replaced,
    Nov 25, 2007 | InFocus ScreenPlay 4805 Multimedia...
    After replace lamp projector stop working no picture. If there a way to reset the projector even if you got no picture.
    make sure all the covers are on tight because they have little switches on them so people dont get a zap.
    May 14, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Projector turns off after 3 minutes, lamp needs replacement?
    Try reseting the filters for the lamp and also clean the air/dust filters.
    May 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    How to replace lamp
    use a flathead screwdriver and pry open the lamp door (looking at the front, it's on the left side of the projector). unscrew the 2 screqws holding the lamp in, unplug the lamp plug, pull lamp out, replace.
    Mar 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus 4805 Lamp will not ignite after new bulb and reset.
    it there is no high-pitched squeal when it starts up, the colorwheel needs replacing. the lamp won't light without it. the part is under $50, but installation is quite involved.
    Apr 16, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Lamp on my infocus 4805 keeps blowing. This is the 3rd one.
    don't forget to clean your pj all 250 hours of utilisation!!
    Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
    My Infocus 4805 suddenly blackout
    First check what is the lamp you using please use lamps recomended by SONY only. That lamps might run up to 2000 hours so.......try checking your lamps and let me know.
    Jan 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
    I have an infocus 4805 and the lamp won't come on. It worked the last time we used it
    The lamp has probably failed. your description of events is a very common way a lamp failure presents.
    Jan 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    173 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
