Question about Philips 55PP9701 55" Rear Projection Television
Green tint screen
I have a 55 inch philip model 55PP9701 and I am seeing a green tint picture which shows all the time I also open the back panel and all three tube are working fine what could this problem be.
Took mine to a repair shop and they said there was an issue with the line something? circuit board. Quoted me 225 parts 450 parts+labor. Mine was a red tinted screen.
Posted on Jun 21, 2007
SOURCE:
Green tinted Screen, Please Help
My tv did the same thing try unplugging the cables and plug them back in and if that don't help you will have to buy a new set my set got fried in a lightning storm :,(
Apr 11, 2014 | Philips 55PP9701 55" Rear Projection...
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
I have a 55 inch phillips magnavox t.v. Im almost positive its a projection t.v., my problem is that the picture shows up really dark, you can see when the show is a bright show, but comes up a weird...
I would say your small signal module is bad. This is the board with the convergence ICs. Have a tech or yourself pull the board out and replace the ICs and some resistors. Checkout TVREPAIRKITS.com. They will have your model and its symptoms. Hope to guide you in the right direction!
Apr 29, 2010 | Philips Magnavox 55P9271 55" Rear...
OK friends. You've helped me with a TV once before. Now I need your help again. I have a 55 inch Phillips rear projection. Model# 55PP970104 Serial# 58610822 Chassis Model# DPTV210 born on 6-13-01 I bought...
sounds like loose solder or crt board...hard to say.
I have the exact set in the shop - same problem - but I have not gotten around to playing with it...
Mine does the same...warms up - works...
Email www.TvRepairKits.com - they may be able to help.
Ed
Jun 10, 2009 | Philips 55PP9701 55" Rear Projection...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
Philips 55
This tint of green may just be one of the chips going out(There are three chips: red, green, and blue.). You can buy these for about $80-$100, but sometimes they are hard to come by(depends on where you are). You may also try to readjust the screen from the back. If you look in the back if you remov the wood that covers the back of your TV, there should be about 6 little knobs you are able to turn(Focus, red, green, blue, tilt, or reset...i think).try that...
It also depends on however long you have had this TV. It this time: you may also want to buy new resistors, for some of them may just blow out right after you fix the chip.(they are about 50 cents-1 dollar).
Hope that helps
Apr 19, 2008 | Philips 55PP9363 55" Rear Projection...
Scrambled picture horizontally
Is this HD on 4 and 5 then it will do it if you don't have a HD signal.
Nov 26, 2007 | Philips 55PP9701 55" Rear Projection...
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Philips 55PP9701 55" Rear Projection Television Logo
370 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
