Question about Lexmark Office Equipment & Supplies
When I try to send a print file to the printer a message pops up as follows: Spooler SubSystem App stopped working and was closed can u help ?
  • 849 Answers
Re-install printer driver after un-installing. delete all print job also.
Posted on Nov 29, 2008
What is Spooler subsystem app?
I would uninstall printer software and reinstall with new downloaded software.
Dec 24, 2014 | Computers & Internet
Tip
Error Message: Spooler Subsystem App has encountered a problem and needs to...
<p><b>Important:</b><br /> <p><span>This article contains information about how to modify the registry. Make sure to back up the registry before you modify it. Make sure that you know how to restore the registry if a problem occurs. For more information about how to back up, restore, and modify the registry</span><br /> <p><span></span><b>Symptom:</b><br /> <p>When you try to start or stop the Print Spooler service, or when you click Start and then click Printers and Faxes, you may receive the following error message: <br /> <p>Spooler subsystem app has encountered a problem and needs to close.<br /> <p>When you try to print, you may receive the following error message: <br /> <p>Operation cannot be completed.<br /> <p><b>Cause:</b> loadTOCNode(1, 'cause'); <br /> <p>This issue may occur if the correct installation and functionality of a newly installed printer is affected by an existing third-party printer driver or service. <br /><br />For example, this issue may occur if the LexBCE custom printer driver from Lexmark is installed on your computer before you add another printer. <br /> <p><b>Resolution:</b> loadTOCNode(1, 'resolution'); <br /> <span> <p><span>Warning:</span></b><span> Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might result in reinstalling the operating system</span><br /><span> <p> 1.<br /> Start the computer in Safe mode. <br /><br />For additional information about starting your computer in Safe mode, click Start, click Help and Support, type <span>safe mode</span> in the Search box, press ENTER, and then click the Start Windows in Safe mode topic.<br /> 2.<br /> Start Windows Explorer, and then delete all files and folders in the following two folders:<br /> &bull;<br /> c:\windows\system32\spool\printers<br /> &bull;<br /> c:\windows\system32\spool\drivers\w32x86<br /> 3.<br /> Click Start, click Run, type <span>regedit</span> in the Open box, and then press ENTER.<br /> 4.<br /> Navigate to and then click the following registry key: <br /> <p>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environment\Windows NT x86<br /> View the list of subkeys. There should be only the following subkeys: <br /> &bull;<br /> Drivers<br /> &bull;<br /> Print Processors<br /> 5.<br /> If there are any keys other than those listed in step 4, follow these steps: <br /> a. <br /> On the File menu, click Export.<br /> b. <br /> In the File Name box, type a descriptive name for this key -- for example, type <span>WindowsNTx86regkey</span> -- and then click Save. <br /><br />You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environment\Windows NT x86 registry key to restore the key if you experience any problems after you complete this procedure.<br /> c. <br /> Delete all keys other than those listed in step 4 .<br /> 6.<br /> Navigate to and then click the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors registry key. View the list of subkeys. There should be only the following subkeys:<br /> &bull;<br /> BJ Language Monitor<br /> &bull;<br /> Local Port<br /> &bull;<br /> PJL Language Monitor<br /> &bull;<br /> Standard TCP/IP Port<br /> &bull;<br /> USB Monitor<br /> 7.<br /> If there are any keys other than those listed in step 6, follow these steps: <br /> a. <br /> On the File menu, click Export.<br /> b. <br /> In the File Name box, type a descriptive name for this key -- for example, type <span>WindowsNTx86regkey</span> -- and then click Save. <br /><br />You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors registry key to restore the key if you experience any problems after you complete this procedure.<br /> c. <br /> Delete all keys other than those listed in step 6. <br /> 8.<br /> Disconnect the printer cable from the computer, and then restart the computer. <br /> 9.<br /> Reconnect the printer cable to the computer, install the printer according to the manufacturer's installation instructions, and then try to print a test page.<br /><br /> <p> <br /></span></span>
on Mar 15, 2011 | Office Equipment & Supplies
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
Scan problems
Hi there
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X5650 All-in-One InkJet Printer
I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
DP-2330 on Vista
To start your spool service type spoolsv.exe in the run box.
Apr 10, 2008 | Panasonic Workio DP-2330 Printer
HP print spooler problem and error 1068. Want my printer back!!!
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
