Question about Lite On SK-7260 (sk-7260(o)) Keyboard
Mouse not working at all
Gave up on trying to get the mouse to work when i got the computer. It says it is working properly but i can not get it to work.
    President:
  • 8,637 Answers
Normal 0 Make sure the batteries are good.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
SOURCE:
Wireless mouse and stick won't work
Have you tried to add a mouse pad under it. I have a capricious mouse myself that has to be on a pad to work fine. If you don't have a pad just try it on a dark surface, no glass that's the worst one...
It can also be a simple battery matter, distance is also important depending of the communication technology in use.
good luck
Nov 28, 2013 | Trust Wireless Optical Mouse Mi-4150K
Single clicks are not working properly in MG-0982 mouse.
i have hp mg-0982 wireless mouse my click r not working properly i have to press i hard to get i work... gave some solution
Jul 11, 2013 | Computers & Internet
I have a problem with the mouse for 5euro This technique tknm110 mouse and the problem that I have a normally lit mouse is a optical mouse, but mouse does not work ... it's two the same, at first I...
Hello ania1997,
I've seen this 'problem' before.
First, disconnect the "Mouse."
Next, click on the "Start Button."
Now, click on the "Control Panel," in the 'start menu'.
Scroll in the Control Panel, and select the "Mouse" applet!
Open the [Mouse Properties], by 2x clicking or,
Right clicking,and open.
From here you want to [Disable the Touchpad Device].
!Beware, that now, you may have to "Manually Navigate."
Without the 'mouse; you will use the "Tab, Arrows, and 'Enter' buttons,
to perform tasks, if the 'optical mouse' doesn't work the first time.
"Restart the computer."
Connect the "Optical Mouse."
"The {Mouse should be detected automatically}."
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Computers & Internet
Someone gave me a computer they also gave me a gear head wireless mouse and keyboard i would like to use them but dont know what i need to do
There should be a software disk that came with it to install, but if not, sometimes you can just plug them in and they should work. If they don't work immediately, email me the make and model of the keyboard and mouse with the operating system on your computer, and I'll see if I can find you a driver.-
Feb 14, 2011 | Gear Head WIRELESS keyboard/Mouse
Plug in
No, you are not an idiot. I believe the problem is that the software 4 your mouse isn't installed properly. If it came with a CD rom then insall it that way. But there is another possibiliy. It could just the usb port on you computer. Either way you not and idiot.
;) hope this helps
Jul 09, 2010 | Logitech Cordless Mouse
Sir, usb mouse is working properly but in,
if the usb mouse is working properly then there may be a problem on the button click of the mouse or, there are viruses on your computer that modified the registry in which you wont be able to do a click on your system . try it on another computer, if it works then there may be mechanical problems on your mouse. Pm me if it works or not. Thank you .
Aug 07, 2009 | Compaq Presario Notebook
Usb mouse problem
Did you install the CD software program that came with your mouse?
If you did and it gave you the unknown device, Then disconnect the mouse receiver from the USB port and reinstall the software program from the CD.
Then if that doesn't work try the following.
Normal 0 Turn the mouse over and find the smallrest/connect button on the bottom of the mouse and press it toReset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then pressthe mouse. This should be done whenever you change batteries orglitch.
Jan 18, 2009 | Computers & Internet
Wireless Mouse Just Stopped Working
Press the connect button on the reciever and then the connect button under the mouse for the computer to recognise it again.
Hope this helps
Nov 01, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Frozen mouse with a touch pad laptop computer
Check your drivers. Go into the device manager (start>control panel>system>hardware>device manager>human interface device) . If it shows a big yellow question mark, than it is a driver problem.
I would suggest that you either install or download the latest drivers for the mouse, and you can do this even without checking for a hardware conflict as stated above.
You can also access the control panel and trouble shoot your mouse through the mouse icon.
Even sometimes this may not work.....
I had an IBM brand optical mouse that continually plague me with problems until I gave it away with a computer that I built. The person who has it is still have occasionally issues with the mouse even with the proper drivers installed. I believe that it is a connection issue because sometimes the mouse will start working when you jiggle the male USB connection.
Oct 14, 2008 | HP Pavilion Media Center a1330n - AMD...
GE Wireless mouse & keyboard
are both keyboard and mouse communicating with a single wireless devices, or each has it's own? sometime you need to sync the signal to the wireless device. but do this first... ask your sister if the mouse was working before she gave it to you, there is a possibility that the mouse is broken/no working. if it's an optical mouse, the mouse that has lights sensor, make sure it lights up...
Feb 16, 2008 | GE Wireless Optical Mini Mouse 3087897985
Open Questions:
Lite On SK-7260 (sk-7260(o)) Keyboard Logo
109 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Damen Wong
Damen Wong
paul shaw
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
