Holmes Products PCH4199V-UM Ceramic Heater Logo
Posted on Nov 29, 2008
Problems with patton Products PCH4199V-UM Ceramic Heater
My heater stopped working it was working fine for 3 days then it just stopped it won't turn on or nothing. i've tried to turn off and followed the reset intructions and nothing still noting not even the lights turn on.
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
I purchased a Patton heater PUH9000 in March 2006. I never opened the box until the other day 1/15/2011 when my blower moter on my furance stopped working. I unpacked the heater and pluged it in........
If it is the same as mine it takes a minute or two to start after you plug it in...this is a safety thing,in case it tips over...if it is tilted to much it will shut off...but will sart back up in a few minutes...
2helpful
I received the Patton Electric Heater model number PUH682 for a Christmas gift. It worked fine for about one week then just about 3 days ago, when I went to unplug it, the plug and cord were just red...
I saw your post and I encourage you to report your problem to The U.S. Consumer Product Safety Commission. I called them to report the problem. The number to the company (Patton) is 763 444 8567. The number to The U.S. Consumer Product Safety Commission is 1-800-638-2772. The U.S. Consumer Product Safety Commission will take your report and if you know others that have this product and they have experienced the same thing encourage them to call and report it. The heater I had melted unto a ultility extention cord and was smoldering. It could have cause serious injury or damages to me and my family.
If this product could have injured you as well. The are a public hazard and need to be recalled.
How do I open my PRH11 heater to clean the senser?
I just used an old toothbrush and stuck in in between the grate holes on the front. I Just brushed on and around the sensor really well & it seems to be working fine now.
My Patton PUH680 space heater is not working. Do you offer replacement coils?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Need a wiring diagram for a Patton PUH680.
Heater stop working found small metal piece with plastic with hook
A small, white, plastic or ceramic part which
TRY AN APPLIANCE STORE THAT DOES REPAIRS. OR CHECK ONLINE WITH MANUFACTURER OR IF SOMEONE CARRIES PARTS FOR IT ONLINE
5helpful
Patton PRH11 Buzzer Sounds on HIGH after 2 minutes
There is a round sensor under the heating elements which sets off the alarm when it thinks it is overheating on the PRH11. Unfortunately, a dirty sensor will fool it into reacting like it is overheated. I cleaned the sensor which was dark and revealed it to be a lighter goldish maybe brass in its original color. If your sensor is dark, it will continue to trip the alarm for overheating and will need to be replaced. If you were lucky like I was and can clean it, the problem should be resolved and it will operate like normal until it gets dirty again. This procedure lasted for 3 days and I had to clean it again. I believe I left the dirt on too long and now my sensor has tarnished plus I live in a rural area with significant dust requiring this recleaning every few days. I only used a damp paper towel with water to clean. Cleaning may work better with alcohol or a tarnish removal solution.
I'm thinking about buying a Patton PCH 199 Twin Ceramic Heater. Do you recommend this product?
Twin ceramic heaters are intense, but, not intended for indoor use without adequate ventilation.They radiate heat and patton is a reputable brand in heating devices.
3helpful
4answers
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
Top Holmes Products Heating & Cooling Experts
Paul Carew
john h
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
