Question about Dell Latitude D620 Notebook
Wireless connection won't work at home
I just got my new laptop. The wireless connection works just fine at work - finding my office network as well as 4 others within range. But when I go home, it doesn't find my wireless network at all. Says no networks in range. (And, yes, I confirmed the wireless is working - that's how I'm sending this right now.) My wireless network is using 802.11b, which is the same at the office. I've checked the settings on my home computer network connection and they all seem the same as the laptop. Why wouldn't it even FIND the darn network? TIA.
I had this problem once and it was being caused by my wireless entertainment speakers. Changed the channel they were broadcasting on and it was fixed immediately. The wireless transmittors for other electronics will sometimes your signal to your computer.
Posted on Feb 23, 2009
As you can use the router to connect to the web, but your laptop is not reporting it, it could be the router is set to not broadcast its SSID, personally I always set this to be true to stop anybody picking up my router if they are nearby. The way to check that would be within the administration of your router, it will either have an IP address of url to go to to log into the admin side, then depending on model, but most do, there will be a section for the router's wireless options, one of which will be to broadcast SSID, if it is unticked, tick it and apply, your machine should then find the router via a wireless connection.
Posted on Sep 17, 2007
    President:
  • 2,961 Answers
Check your router is accepting backward compatible connections of 802.11b, as it may be set at 802.11g only especially if it's a 108 or 125mbps router as your laptop will only be 54mpbs and not see the router at all. Sometimes you have to dissable then re enable the wireless network adapter or refresh it for it to do a new search of networks.
Posted on Jan 17, 2007
  • andrew pester
    andrew pester Jan 17, 2007
    Sorry ignore the 802.11b part as it will obviously connect to your laptop but check speed of your router as 54mbps laptops are unable to connect to 108 or 125mbps without re setting the router to a slower speed.
    This will not effect your internet speed, only local are connection file transfer speed.
SOURCE:
Err connection reset
Obvious thing, but have you already tried restarting the router? Sounds like an odd problem for it to only happen with wireless that that router with that laptop. That error looks like a Google Chrome error. It may be worth seeing if you still get the error with Firefox as well.
Jan 06, 2014 | NetGear Computers & Internet
WNDR3400 windows 8
Possibly. There are things that needs improvement for Windows 8 synchronizing with other devices.
Mar 09, 2013 | Computers & Internet
The mail function works fine on my home wireless network, but won't work on the office wireless network. I've occasionally found this problem with some hotel wireless systems. Other internet functions...
the mail is needing two servers to work:
- pop server to get your mail, you can acces to it everywhere
- smtp server to send mail, you can only use it from your home wifi.
To send mail from evrywhere, you had to go on your provider website
Dec 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
MSI VR 220 can't find wireless network at home. It can connect to the internet directly with the use of a cable. It also connects automatically to the one at the office. MSI VR 220 can't find wireless...
you can try and connect it with the cable first and access the GUI (Graphical User Interface) to configure the settings of your wireless gateway/ router. it is possible that the settings are not configured in a way your laptop would be compatible with it...
hope this helps...
Nov 28, 2009 | Computers & Internet
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
I want to connect at home
Around the office, your laptop is probably connected to a wireless network which you don't have at home. To connect, you would need to connect to the office network from your home through a VPN (Virtual Private Network) over the Internet or through a dial-up (ugh!) connection to the office systems. Your office IT staff should be able to help you get that set up since either way it would require some configuration on their end to allow you to connect remotely to the office systems.
Apr 18, 2009 | Dell Latitude D600 Notebook
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Unidentified network
Your office network is probably hidden you will need to change the settings on the router. Talk to your Net Admin about it.
May 21, 2008 | Dell Inspiron 1501 Notebook
Dell Latitude D620 Notebook Logo
303 people viewed this question
Clive
Clive
Alun Cox
