I have a vgc-rc110g and want to buy a better hard drive for music recording/production/mixing i have some knowledge of hard drives as i spent countless hours researching the question is that i opened the panel that gives me access to the hard drive and i found 3 additional SATA plugs from my current knowledge that means i can add a total of 4 new hard drives to my computer if i was to replace the existing one... thats all pretty clear but i dont know what hard drives to add in terms of capacity 500gb/1tb/2tb im pretty sure i cant just add whatever hard drive i want because i have to make sure it is compatible with the motherboard if it was up to me i would add 4 new hard drives 1tb 7200rpm each but im not sure if that is possible whats the maximum hard drive capacity i can add to my computer? i plan on using this desktop strictly for music and need a good hard drive(s) so i will consider any brands referenced i would really appreciate the knowledge, advice and time you spend in helping me out
I have this machine and love it. Bought it refurbished and added 4 x 1TB WD green drives. Using the built in RAID Controller I am running RAID 1 ( mirroring) on 2 sets. So I have 2 TB total available. I am considering upgrading the drives myself, but do not know the max the Bios will support, I would love to swap out the 1 TB for 3 or 4 TB and continue to run RAID 1. But still don't know what the max capacity the BIOS Will recognize.
SOURCE: Fails Post
It's the HDD, or the HDD controller. Give sony a call. Based on the number and sequence of beeps, they can tell you exactly what this issue is.
SOURCE: need the motherboard layout for this board out of viao vgc-rc110g
You will find as with Dell that the motherboard etc is all custom & you cant upgrade it yourself, you have to go through Sony. I am not 100% on that but that has been the case with many branded PCs i have seen.
Can you not open the case? This usually voids the warranty but if you were intending to replace parts then it would likely be voided anyway.
Thanks
SOURCE: I want to upgrade the motherboard in my Sony VAIO
all VAIO Desktops are IBM Compatible. An ATX motherboard will fit.
SOURCE: How do i access the hard drive on Sony Vaio VGC LS-25E?
Remove the screws for the mount as well and take it off from there the back will just pull right up
lol david thats the exact hard drive i was planning to buy i just wasnt 100% sure if it was compatible....by the way i have a 32 bit .....should i just add 1 caviar black 1TB hard drive or should i take advantage of the 3 additional SATA plugs?
1 bt hard drive is quite a bit of memory.one will work just fine if you fill it up get another.
