Question about Intel Desktop Board D845WN Motherboard
I can not boot my pc with intel MB845 chipset,error in first
Error in first blue screen,system file not found ,fatal error 4, i check my ram,processor,agp hdd,cd rom, xp cd everything ok. my bios run but cannot load windows xp, windows 98 setup can completed but not open...is my MB ok, pls help me ...
Regards,
Prince
  • 849 Answers
RAM, Processor and Motherboard could cause the same problem. check all these.
some time virus also not allowed to install windows.
Posted on Nov 29, 2008
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 11, 2012 | Dell Inspiron M5030 Laptop
My phone is showing blue screen with "error fatal
1. remove the battery and power cable 2. remove the sim and memory card 3. reinstall eveything 4. estart your system
Jan 28, 2011 | LG Vu CU920 Cellular Phone
I am getting error 51 on the lower right of the screen right after post and machine will not boot
Hello.
I did some research and I found this article:
When a USB device (such as a USB memory card reader or USB camera) is connected, you may see the following issues:
  • System boots more slowly than usual
  • POST code error 51 appears at the bottom right corner of the screen
If the USB device is not connected, the system boots at a normal speed without any errors.
To resolve this problem, download and install the latest chipset driver and the latest BIOS. Chipset and BIOS files are available on Download Center.
http://www.intel.com/support/motherboards/desktop/sb/CS-031767.htm
this seems to adress your issue. I would start there and if you have more issues let me know
Hope this helps!
Please vote if so :)
Jan 26, 2011 | Intel Motherboard
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Frequently get a blue screen with a Fatal Error message.
Blue screen while running indicates that the OS (one of the file) has been as been corrupted.... Re installation of the OS will solve the problem
Thanks...
Jul 19, 2010 | Dell Dimension 3000 PC Desktop
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Problem loading into windows 7 after updating bios
FIRST - you didn't use the bios update from ASUS?
Second - USE CORRECT HEADER FOR QUESTION
Third - This is an
Intel® Desktop Board DG31PRCorrect?
Found Different BIOS file than one you used.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2839&DwnldID=18881&lang=eng
ALSO = List of ALL BIOS Updates (quite a few)
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
BIOS you used is two years old - on page 2
Try a newer version
Apr 04, 2010 | ASUS P5LD2-VM Motherboard
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Windows cannot loaded at bootng time
check the RAM use it on different slot or use a different RAM
Oct 13, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Intel Desktop Board D845WN Motherboard Logo
159 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
