Question about Sylvania 6626LCT 26 in. LCD Television
Hi, how can i fix the problem of my tv that turns on and off
  • brookann79 Dec 20, 2008
    My television automatically goes to stand by when I turn the power on.
    ESTEBAN MERINO May 11, 2010
    it just fix a sylvania tv with the same problem. try unpluging the set for a couple of hours and let's see what happens.
    Problem Solver:
  • 17 Answers
Unplugging a set for at least 20 seconds then plugging it back in only resets the microcomputer in your TV. This sometimes does help, but a lot of cases it does not.
It's likely your set needs a new SMPS power supply. Goto this link for a model search:
Click on the GUEST LOGIN link on the right hand side of page in a blue bar. Once after logging in, you can then do a model search. If your model does not come up, then goto the CONTACT INFO page for phone numbers and start calling. Someone there maybe able to help you find the part needed to get your set up and running again. First part you should try replacing is the SMPS power supply board.
Good Luck
Posted on Jan 18, 2009
When i turn on the tv, it clicks on and the fan fires up for about two seconds then the tv turns off. then the red power light flashes three times, and continues to flash in that sequence. i have a sony...
Did you replaced/ took out lamp from tv to inspect it?
3 times red light flashing shows that lamp cover has not been fixed on tv, lamp cover is first thing that needs to remove to take out lamp from tv.
Please check lamp cover and make sure it is fixed properly on tv.
Mar 28, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
KP57WS500 Screen turns Blue and then shuts off. Can this be fixed?
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Apr 03, 2010 | Televison & Video
Hi, Sorry this is not a fix but i wanted to say that i have the same problem on my tv which is the same model as yours.
At start tv would show faint parallel diagonal lines until some day it stopped working. Everytime i try to turn it on it doesnt! and makes a ticking sound from the back of the tv. Did you fix yours btw?
Feb 22, 2010 | Samsung WS32Z308P 32" TV
Hi the tv just wont turn on...
most likely its your J2 noise reducer. it filters out the static in the electrical line to convert or power to a resonable voltage to use. however when the go bad the tv filters in to much power thus casing a power surge blowing a internal circuit so u have two options a go to a local repair shop and get them to fix it or throw away cause u will spend more fixing it than what is truly worth sorry.
Feb 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Green Flash and turns off
its in your power supply and colorwheel it would cost about 600 maybe more to fix
May 27, 2008 | Sony KP-51WS500 51" Rear Projection...
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
May 01, 2008 | Televison & Video
Can't turn TV on because buttons on TV locked accidentally trying to fix convergence
Hello Regina50,
I would suggest that you have a TV technician come out and check your TV. This may cost you a little bit of money, however it will be worth it.
Thank you,
Nov 01, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sylvania 6626LCT 26 in. LCD Television Logo
98 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
