Question about Maytag MGR5770 Gas Kitchen Range
Oven igniters, are both suppose to be on during preheat or bake?
Maytag MGR5770....
The oven has two igniters, an upper one (usually used for broiling) and a lower one for baking. When you set the oven control panel to broil, the upper igniter works and the digital display on the control panel shows an orange upper bar, as if to signal that the brioler is on. However when you choose bake, the upper and lower bars are visible on the control panel display.
Question: when choosing "BAKE" does the oven use both upper and lower igniters?
The bottom igniter is the only one I see as active when baking. I do believe that the bottom igniter needs to be replaced, but I want to make sure that the igniter control unit is working properly. (Original problem... oven taking too long to preheat, sometimes smell gas. Lower Igniter is activating but does not glow as brightly as the upper one. I am planning to replace the lower igniter).
  • blindmanbruc Nov 29, 2008
    ... if it does, then I may have an additional problem, where the upper igniter is not operating when "bake" is selected.
    :) Thank you.
  • Anonymous Dec 09, 2008
    Bake ignitor is not bad on mine. Bottom ignitor works, but oven takes a long time to preheat. Broiler ignitor works if you only ask for broil, but does not come on, as it is supposed to, when in preheat mode.
Where is the bottom bake igniter on the MGR5770adw do I have to take out the bottom pan in the oven or am I missing something how does the pan come out duh??
Posted on Aug 30, 2009
    Sergeant:
    Champion:
  • 324 Answers
Good choice,sounds like the bake igniter is bad
Posted on Nov 29, 2008
  • The top one should come on for broil.
    it may not come on for bake.
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake...
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Oct 20, 2013 | Maytag MGR5770 Gas Kitchen Range
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
We have a Maytag gas oven and it takes close to 30 min just to preheat to 350 degrees, however the broil setting works great. Any help would be great...
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Aug 28, 2011 | Ovens
Maytag oven model mgr5770 oven hard to light and doesnt keep temp even when it does gas stops lighter still glows?
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Aug 01, 2011 | Maytag Kitchen Ranges
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
WHen turning on the oven to bake it will not ignite a flame. I can broil and cook on top however the gas will not lite when baking. The pilot is on however the gas will not burn unless banging on the part...
This is usually a symptom of a faulty oven safety valve. Over time, it tends to stick internally and banging on it helps unstick it. You can either continue banging on it for faster burner ignition or have it replaced. You'll need the make, model # and sometimes serial # if it's an older model, to replace the part. If you do it yourself, be sure to close the shut off valve behind the stove before you remove it. Douglas
Aug 18, 2010 | Maytag MGR5770 Gas Kitchen Range
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Maytag oven doesn't light, broiler comes on instead
On some gas ranges, the broiler comes on with the bake selection during warm up. This allows the oven to preheat much quicker. More than likely, the control pad is functioning properly and your bake igniter is bad. Igniters become weak with age and eventually go bad. Since the bake feature is used more frequently, it typically goes bad more often. The following link provides you with some guidance on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Remember: just because an igniter glows, does not mean it is good. If they become weak, they will not draw the required current potential to open the gas safety valve.
If you determine the igniter to be bad, you can obtain a replacement at searspartsdirect.com. Just type in your model number and go to the "Gas Controls" heading and look for item number 14 (part number 74007498). If the igniter plug does not match the plug you have on your oven, the instructions will guide you to cut the wires and splice the ends together. There should be ceramic wire lugs that come with the igniter kit. CAUTION: Make sure you only use the ceramic (heat resistant) lugs that come with the kit. Splicing with regular wire lugs or electrical tape will melt due to the heat. Additionally, make sure you UNPLUG the appliance before replacing the igniter. Live voltage potentials are still present with the range shut off.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 11, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Maytag MGR5770 Gas Kitchen Range Logo
642 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
